Asus Chromebit RK3288
Has anyone had their hands on one of these https://www.asus.com/uk/Chrome-Devices/Chromebit-CS10/ and only just seen them looks like same spec as the R89 im quite tempted. They run chrome which isnt android I know but should be easy enough to flash just need to see which wifi chip it is and the kernel should be really up top date i would hope. Maybe plenty of source code available from asus
Nice device but if you want to run Android on it this might be a problem. If there is no source code for kernel then it might be almost impossible to run Android on it. Even if it has similar parts as Beelink R89 these devices have different internal connections (mainly GPIO) and that must be properly configured mostly in DTB. I also doubt that Asus used ACT8846 as PMIC.
Even so it seems that you can install Linux there.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Some time ago Google mentioned something about unifying Chrome OS and Android. I hope they can manage it.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by scooter2014 View PostAll of here at Freaktab have been waiting on this for few months when Neomode showed us in conversations. So we like this move alot. 😀 note mali gpu different then most 3288 soc.
There are currently 2995 users online. 1 members and 2994 guests.
