Pipo X7S - Deleted Android Partitions to make space for Windows 8.1, can't boot properly...Windows repair screen shows
    I used a free Minitool Partition Wizard to delete the Android partitions inside Windows, it then asked me to reboot to resize Windows partition.
    I still get the boot option to select Android or Windows
    When I select Windows, it looks like Windows tries to boot, it shows the spinning dotted circle at the center bottom screen, it then gives Windows Error and need to restart, the next restart it says Preparing Automatic Repair which never works. I've gone into Advanced Options and tried using the command prompt bootrec /fixboot commands but nothing is working
    Anyway to fix what I did?
