Where can I get Beelink's LiteHome home screen/launcher,not in Play Store.How 2 clone launcher 2 install another same device.
Where can I get Beelink's LiteHome home screen/launcher? its not in Play Store. Also is there a way to clone launcher so I can install it on another same device, this way I don't have to spend so much time installing the same again.Tags: None
Hi mate, Try this https://www.dropbox.com/s/4dukfdomd7...thome.apk?dl=0
This came from model GT1.
Cheers
Kevin
Thank you so much Kevin, but it did not work. I tried the file on two different Android Boxes & after installed, I changed my launcher to LiteHome & screen went crazy, flickered & they both crashed. Have you ever tried the backup copy you sent me? Maybe I will have to try another copy from somewhere else. Thanks for trying to help me out. JD
Two boxes failed & it was a little scarry, but just might try again. All I did was open the app & installed it. After that it was added to settings/home where home screens/launchers are located & I clicked on LiteHome & that is where it failed on both of these devices. Matricom G-Box Q2 2GB/16GB Amlogic Quad core S812 Android 5.1 Lollipop & the other box is 3GB/16GB H96 Pro+ Amlogic S912 Octa Core Android6.0 TV Box Set-top Box 2.4G/5.8G 64bit. I sure like how it looks & runs on Beelink, but will be giving this to a friend & will not see this wonderful home screen again. I noticed that Beelink has a backup restore & am wondering if I can back entire system from Beelink & restore it to a different box. I'm afraid that may be the wrong way to go at it, but it did cross my mind. I wish they placed it in the play store, any ideas on how to get the LiteHome homescreen to work on other devices?
There are currently 1121 users online. 1 members and 1120 guests.
