MECOOL BB2 PRO Android 6.0 TV Box 3GB DDR4 + 16GB & (Review)
Originally posted by trebor View Post
If not, can you point me to the difference?
Hi, I bought this device...an BB2 Pro 3Gb/16Gb Mecool with 7.1.1 Android version.
1) I was disappointed for default lancher and even if you change the default launcher when you restart device the default launcher is loaded before...
2) However I can keep the default launcher but I don' t know how can I set the status bar.
If you go in Settings->Display I don't find status bar item to activate the bar...and for me is very important this feature.
3) The last thing is that the TvCenter (Kodi) takes a long time to load. Why?
MECOOL BB2 PRO S912 3GB/16GB TV BOX FIRMWARE UPDATE 20180202
As found
USB tool
SD card
http://geekbuying.mediafire.com/file...80202.zip/file
Source blog.geekbuying
This is by far the BEST firmware I've ever used on the MECOOL BB2 Pro. It is for the X98Pro 3gb or 2gb ram version.. More specifically this X98Pro 2GB / 3GB RAM, USB-PC Upgrade 10/16/2018 (Android 7.1.2) X98 Pro [Android] (Post yalex13 # 79858966)
The only downside is the REMOTE DOESN'T WORK and WIFI DOESN'T WORK and probably Bluetooth which I haven't checked.. I USE A KEYBOARD AND ETHERNET PERFECTLY! But this is NORMAL ANDROID!! and even tho it may not be DDR4 ram, I'm not sure.. This Rom runs fast and smooth .Google play store works but doesnt seem to update. But this firmware is fast. I'm hoping someone can get the WiFi from BB2 PRO and make it work with this FIRMWARE and tweak and update playstore for us. Fix so our remote will work as well.. It would make our Mecool BB2 pro worth using. Trust me! I use this now as Ethernet works fine and all apps seem to run well. If anyone can check this firmware out and modify it for the BB2 PRO IT WOULD BE MUCH APPRECIATED. Save our android box. NORMAL ANDROID !!! No more ANDROID TV.
Originally posted by jimennis View PostBluepoison atv rom working on my bb2 believe also on the bb2 pro
There are currently 2517 users online. 7 members and 2510 guests.
