You don't need to install TWRP, you can run it from the SD card as the instructions on 1st post.
Minix Neo U1 firmware port for MiniMXIII ánd Mini MX! Prerooted + TWRP recovery
Originally posted by dommels View PostBased on Minix Firmware: NEO U1 FW010 - 20161012
Change log since FW009A:
1.) Updated Miracast app
2.) Fixed Wi-Fi static IP connection issue
3.) Updated MINIX XBMC app to fix HD audio passthrough issue (Build 20160911)*
4.) Removed system broswer to allow Android system webview support
5.) Added Chrome browser (You may also install your own preferred browsers)
6.) Modification to support up to 5 USB devices
7.) New mouse icon of medium size
8.) Fixed audio issue on some games (e.g. PACMAN 256)
9.) Added a software switch for video layer output (default is still OSD layer)
10.) Fixed some x265 video playback issues (e.g. Dragon Ball Super)
11.) Fixed ghosting, smoke effect on some SD videos
Everything working. Antutu score: 36913
Firmware : https://mega.nz/#F!d1MhSZzT!Eg6mfZwpfWUPh9hacYsMVw
Files needed per device:
Mini MX (AP6212 version):
recovery.img
MiniX_NEO_U1_FW010_To_Beelink_MiniMX_V1_Ap6212.zip
MiniMX_v1_Ap6212_WiFi_Driver_Patch_FINAL.zip
Mini MX (RT8723 version):
recovery.img
MiniX_NEO_U1_FW010_To_Beelink_MiniMX_V2_RT8723.zip
MiniMX_v2_RT8723 _WiFi_Driver_Patch_FINAL.zip
Mini MXIII:
recovery.img
MiniX_NEO_U1_FW010_To_MiniMX3_FINAL.zip
MiniMX3_WiFi_Driver_Patch_FINAL.zip
Instructions:
Put files on USB stick or SD card
Boot in recovery
Go to advanced wipe, select and wipe Dalvik / ART CACHE, CACHE, SYSTEM, DATA.
Go back and flash two zip files (firmware first, then patch!)
Reboot system.
First boot can take a while.
Source: prohardver.huYou may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoMINIX U1, MINI MXIII, MINI MXIII II, GT1, SEA I
Originally posted by starfall View Posti am using a mini mx, i wipe the box following the instruction and flashed the rom. however i got a black screen and only can revert to 107l with usb burning tool
can anyone advises me for flashing this rom?
thanks
thanks
pull out power and insert usb thumb drive to side port
press reset button and hold than plug in power jack and release reset button
recovery mode pop up and select ***.zip until it reboot and do it same for wifi patch..
Originally posted by KAA View Post
check your wifi model and copy 3 file to usb thumb drive
do u know how to check the model?
i flashed two zip and then reboot, it seems i shall flash 1 zip, reboot and then flash the other one?
i flashed two zip and then reboot, it seems i shall flash 1 zip, reboot and then flash the other one?MINIX U1, MINI MXIII, MINI MXIII II, GT1, SEA I
As stated you need flash main firmware first...
i still get a black screen after i flashed the main zip only and then reboot
i also tried the img of Neo U1 FW009 for MiniMXIII, it works for me with wifi not functioning
i did flash the main zip and then the patch, but i just reboot once after i flashed two zip
i also tried the img of Neo U1 FW009 for MiniMXIII, it works for me with wifi not functioningMINIX U1, MINI MXIII, MINI MXIII II, GT1, SEA I
Just for providing a big thanks about this ROM.I have followed the procedure in order to flash my Beelink Mini MXIII with success. ROM is working fine (wifi included). I'm wondering about the update available inside the ROM (through the Neo update), is it a good idea to launch the update ? I don't think so.. But just to confirmIs it the version FW011 .. ?
thanx, this ist the best working ROM with my MiniMX. wifi (AP6212) performance was very bad (about 3 mbs) but after installing (just with twrp) the patch "FIX_WIFI_Mini_MX.zip" wifi works also fine (about 23mbs).Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
There are currently 4266 users online. 1 members and 4265 guests.
