S400 Stock Rom and Unable to flash via PC
Do you have a link with for the Azuril Rom and a CWM for the S400 by any chance.
Originally posted by humpty_dumpty_empty View PostHi Mate...Plz try Azuril ROM ...should be good and fit ur device... Do let me know if you need one..will dig out from where did I hunt it...Thanks.
This is a plea for help
Hello this is not my first time flashing a TV stick but it is my first time flashing a s400 what prompted me to do this is the s400 stick kept shutting down and restarting as well as dropping wifi signal. I assumed I did not have the Green Dot version and flash one of the non green dot stock firmware from this forum thread when I flashed with the Rockchip_Batch_Tool_v1.7 with recovery i got this (in red layer 1-1 download firmware fail) i got this on all the firmwares that i tried from the links in the cozyswan thread both green and non green. So I assume I am brick now due to the fact I can I get any video from the stick, but I can still I can still access it by hitting the reset button on the side and running Rockchip Batch Tool.
so am I screwed or is this salvageable?
Originally posted by prototype386 View PostHello this is not my first time flashing a TV stick but it is my first time flashing a s400 what prompted me to do this is the s400 stick kept shutting down and restarting as well as dropping wifi signal. I assumed I did not have the Green Dot version and flash one of the non green dot stock firmware from this forum thread when I flashed with the Rockchip_Batch_Tool_v1.7 with recovery i got this (in red layer 1-1 download firmware fail) i got this on all the firmwares that i tried from the links in the cozyswan thread both green and non green. So I assume I am brick now due to the fact I can I get any video from the stick, but I can still I can still access it by hitting the reset button on the side and running Rockchip Batch Tool.
remember what you had botlader, if you upload to another botloader hang device. I wrote soon not have the original stick from COZYSWAN, all other are counterfeitsMY MINI PC: C4,CS918,M8,M8C
Originally posted by darekmarta1975 View PostI work those you upload the flash to original rom
Originally posted by prototype386 View PostI don't understand I think mine is an original but if it is a counterfeit do you have a ROM that would work with it
uploaded to the server it'll give you the linkMY MINI PC: C4,CS918,M8,M8C
Originally posted by prototype386 View PostOk by what do you mean by " uploaded to the server " upload what??
Just look here, i made i Package - http://www.freaktab.com/showthread.p...400-All-in-One
and after you can look at my new ROM MOD - http://www.android-hilfe.de/rockchip...10-rk3188.html... TVDroid
> > > Devices: Minix Neo X7 & HiSilikon® T-R42 II < < <
Originally posted by darekmarta1975 View PostFirmware BOTLADER 2.07
http://sendfile.pl/116670/S400_sihe_...oot_201114.zip
Glad to know there's someone here that knows there stuff and not afraid to help someone
Thanks Again..
Originally posted by TVDroid View PostJust look here, i made i Package - http://www.freaktab.com/showthread.p...400-All-in-One
I only upload by shorting the pins will help.
Such information is needed from unnecessary downloading, a lot of people wearing damaged and later wrote to me in PMMY MINI PC: C4,CS918,M8,M8C
No thats not true my Friend, on my S400 i have all Versions tested, the worst that can happen is the MASKRom MODE. And this you can easy leave with the BatchTool and a Update instead of Restore.
Believe me, i'm sure i tested more than 30 ROMS and my Stick works great with this Rom i post here.
But here ... (iam new to this and maybe i only have Luck)
Need more to know ? Base is that ROM - http://blog.geekbuying.com/index.php...ndroid-tv-box/... TVDroid
Originally posted by TVDroid View PostNo thats not true my Friend, on my S400 i have all Versions tested, the worst that can happen is the MASKRom MODE. And this you can easy leave with the BatchTool and a Update instead of Restore.
I know what I wrote, deals with the MINI PC from one and a half yearMY MINI PC: C4,CS918,M8,M8C
My Device is not bricked and i flashed Bootloader 2.03 many Times and now i flash Bootloader 2.0.7 and all is good. Maybe with other Devices this makes trouble but on my not.
This is my - http://www.****.de/itm/171174124452?...84.m1439.l2648
Or what you mean ? You speak German ? Please send me PM Dude.... TVDroid
Originally posted by TVDroid View PostMy Device is not bricked and i flashed Bootloader 2.03 many Times and now i flash Bootloader 2.0.7 and all is good. Maybe with other Devices this makes trouble but on my not.
I buy directly from the manufacturer who produces the device not from pseudo Companies
S400 manufacturer is the company COZYSWAN and not some pseudo companies each buy on **** or other auction sites.
I write to you as when you upload the rom with botladerem 2.07 is 2.03 botlader it will crash device or in the worst case, you do BrickMY MINI PC: C4,CS918,M8,M8C
There are currently 2899 users online. 0 members and 2899 guests.
