S905x (08/2016) MXQ Pro Plus 4K - some remakrs, experiences and questions
    Hi Freaks!
    Today I learned the hard way that the MXQ Pro+ 4K released after September 2016 is a completely different device in terms of firmware. The board layout is different and "S905XQ_v1.0" and the date "2016.08.11" is printed on it.
    Here's the link where you can find the photos of the board: https://goo.gl/photos/ri8XkATCcNU1xCnx7
    First none of the ROM's posted in the other threads worked, neither did TWRP.
    After I went reckless with USB Burning Tool I tried to unbrick it for the entire day.
    I've had only half of a success, because there's no stock firmware available on the net for this model so I can't go back. The one that loaded is for Nexbox A95X, but the WiFi doesn't work.
    Does anyone of you know where to get the stock firmware?
    Secondly, does anyone of you know if a working S905x firmware can be modded to fix WiFi? Do I need to rebuild the kernel or something?
    Thanks for any info.
    Update: I can confirm that this ROM works with WiFi: http://freaktab.com/forum/tv-player-...s-v88-pro-port
    I have the Original MXQ Pro firmware. It is for the S905XQ_v1.0 with the date of 2016.08.11. Download the firmware here https://mega.nz/#F!p6Yy0aRS!YvvVLwLn8J6hMs9o3Via4Q
    MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
      I can't download from the above mega link. I am having a mxq pro+ which is running marshmallow, I would like to check if the ROM posted above matches with what I am having.
      Or is there anyone has the ROM for this box which is based on S905X ( instead of S905 ) ?
      It has to be Marshmallow and above.
        Try this link. It is Android 5.1.1. If you have 6.0.1 please post it.
          I have marshmallow. I want the unexpanded (installable ) firmware.
          As the thread starter said, there seem to be multiple different devices under the same label. To move forward we need to find firmware based on S905X with marshmallow.
