Anyone use Bluetooth Headphones with the X5?
    I was thinking of getting some Bluetooth Headphones to us with the X5. Has anyone done this? The
    Kinivo BTH240 Bluetooth Stereo Headphone works with the Android phone so it should work.
    https://www.youtube.com/watch?v=WRcXnVsoyRY
    I have the same question, because and try to use it on a MK802IV i does not work.
      I ended up buying a set ofKinivo BTH240 for 30 bucjs and they work fine. I even got a usb 3.0 hub with the order for free. LOL
        Thank's for your reply.
        I'm thinking to change my MK802IV for X5 (or new X7).
        Do you noticed any delay when play movies?
        Regards
          Regards
          I notice when playing video files from my network there is no audio delay. When using XMBC there is a delay. That is fine though as XBMC has an Audio Offset setting in it. Its not reallly bad it is just one setting off zero.
