leolas.
RK3188 tun.ko for VPN support
Re: RK3188 tun.ko for VPN support
Originally posted by iceberg View Post
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by iceberg View PostThanks for that, but I'm still having a great deal of difficulty setting up my Astrill VPN/OpenVPN. Any tips you can suggest?
Cheers.
TUN.tko Installer
Originally posted by Desperado_22 View PostDid you try that free tun.ko installer app in Playstore? That worked on my MK808b rom with the VPN app I use.
There is a much easier solution to this **//works on Android 4.4.2 Kernel Version 3.0.36+ with an RK3188 Android TV box//** loads of modules collected and loadable it actually installs it so you can collect it without searching, can confirm that Open VPN would NOT work before installing this after, it works fine, BUT you have to run it every time you 'restart' if you just put the box to sleep them its fine it just works all the time.
Originally posted by Skelmy View PostThere is a much easier solution to this **//works on Android 4.4.2 Kernel Version 3.0.36+ with an RK3188 Android TV box//** loads of modules collected and loadable it actually installs it so you can collect it without searching, can confirm that Open VPN would NOT work before installing this after, it works fine, BUT you have to run it every time you 'restart' if you just put the box to sleep them its fine it just works all the time.
http://forum.xda-developers.com/show....php?t=1416540
Originally posted by Jomico View PostSorry but it doesn't work on rk3188 android tv box so please stop trying to misinform all and sundry.
OH that is funny I MUST be seeing things then as I HAVE had it running for the last 3 months o.O IT is running at the moment on my Android RK3188 CS918 V2 box!! 100%
Otherwise I am seeing things.
I THINK YOU should not tell me what I know and do not know and what I have or haven't done............ I will take a screen shot to PROVE it.
Hi
Originally posted by Jean18 View PostHello. I have an Android 4.4.2 Kernel Version 3.0.36+ with an RK3188 Android TV box (Q7).
Y use Tun.ko installer that say it's ok but when i launch Openvpn connect that start and immediately the box restart. Can you help me please ?
Originally posted by Skelmy View PostI don't know then mine only resets of there is a loss in internet connection. Have you got the Lan (wired internet) turned on? or are you on wifi?
There are currently 2275 users online. 1 members and 2274 guests.
