(Official International Version) Original Xiaomi Mi Android 4K Media Player Quad-core Cortex-A53 2/8 GB
    ● A high performance of Quad-core Cortex-A53 CPU can play a wide range of games.
    A Bluetooth voice remote control: Just speak into the remote control and Mi box will search for what you want.
    HDR 4K H.265 VP9 Profile-2 4K Decoding will provide you with a scene in vivid contrast, color and clarity.
    HDMI 2.0 is a faster way to send video and audio output to your TV.
    ● It also supports both Dolby and DTS encodings which create you smooth and surround sound.
    Gearbest
    Xiaomi Mi TV Box Amlogic S905X Quad Core
    My look at mi Box first some a few pictures of this well packed unit
    Bit of a look at the Inside not a lot to see all covers soldered, so must be secret stuff.
    First look and fiddle with Mi Box 3 (Official International Version) great if you like the TV format layout, and if you dont own a smart TV or just a monitor then this would take care of Business easy.
    Mi Box 3 has all the Goodies of a good streaming unit, Googly supported. pretty easy if you ask me.
    As more get out there I feel this may improve with some creative thinkers if not already.
    The Unit is small no lights or annoying leds
    The Remote is excellent voice commands, and can point just about anywhere and you have control solid feel to it.
    As seen in other reviews abouts it's not a strong game player graphics wise, but will do the family orientated games etc with relative ease.
    I will be doing some testing etc over the next few days, I think it has nothing much prove it was built with a purpose in mind and should cover that easily.
    Gearbest
      Another Look at the Xiaomi Mi Android 4K Media Player Quad-core Cortex-A53 2/8 GB
      The Mi Box is the first Xiaomi product I have used. I received it beginning of December and have been using it regularly since then. I have received 3 updates which went through uneventfully. I was very pleased with this box. I ended up getting one for my in-laws and one for my 4 year old sons bedroom. The UI worked as expected. I have an Nvidia Shield Android TV, and the Mi Box complements it very well. Having Plex Server running on the Shield and Plex on the Mi Box is pretty fantastic to easily share content. Not to mention way more cost effective than putting a Shield in every room.
      What’s Inside
      Click to Enlarge
      The build quality is good. The power supply puts out 5.2v which is not typical.
      I do wish it had more USB ports. A single USB is inadequate. I found myself swapping USB out frequently during testing. There is optical audio and it has the round form factor. Luckily the cable I had had the adapter attached to the end, and it worked fine. No Ethernet adapter is present either.
      Click to Enlarge
      Teardown Photos
      Click to Enlarge
      Click to Enlarge
      Android TV UI
      For anyone unfamiliar with Android TV UI I took a few screen shots. Across the top in the first screen capture a recently used/suggestion line appears. The top line will update based on your usage games, TV shows, YouTube, news etc.
      Click to Enlarge
      Not all apps populate this. HBO GO, Plex, Netflix, do update. Immediately below there is a MI Box Recommends section which is static.
      Click to Enlarge
      I was able to disable it under setting > apps to unclutter the main screen. These screenshots were taken when I first plugged in the box. I personally like the UI of Android TV and appreciate that Google ensures all apps to work with remotes and a mouse/touchpad is not necessary.
      Click to Enlarge
      Casting
      Another thing that I was forced to use because DirecTV Now does not have an Android TV app yet, is the casting feature. I had it on the Shield but never really used it. Between casting my screen from my phone to most video apps I found it very easy to use. My son will navigate YouTube Kids on his tablet and cast to the TV. This is a feature you won’t find on most android boxes and I found it very convenient and easy to use. Voice Search
      During my usage and showing my son how to use the voice search I grew to like it a lot. Voice searching that is able to return YouTube, Netflix and other video apps is really convenient. My son is 4 and doesn’t speak very clearly yet but it does a good job of recognizing his voice allowing him to find the video’s he wants. (minecraft, lego, minecraft, lego, minecraft, lego) Passthrough and Auto Framerate
      I spent many many hours trying to find a good combination in Kodi/SPMC/TVMC/FTMC and couldn’t get it to work consistently. DTS only worked for me. I hope they resolve this with software in the future. Benchmarks/Testing
      This is not really fair but I performed a side by side comparison of 3DMark: Xiaomi Mi Box vs Nvidia Shield. I thought it would be interesting to see. Fear not, the Mi Box does well with light gaming. I had no problems playing games that didn’t require a controller.
      Click to Enlarge
      WiFi is fair at about 15Mbps on my busy Unifi 2.4 GHz network. I also have a 5GHz N built into my router and strictly using it for testing. I was able to get about 30 Mbps throughput. I still prefer a wired connection when possible and was able to use a USB to Ethernet adapter on the MI Box. I moved 2 files below one on 2.4ghz and one on 5ghz. I don’t have an AC network to test.
      Click to Enlarge
      I ran a few other tests and info apps below.
      Widevine Level 1 Supported – Click to Enlarge
      36,151 points in Antutu – Click to Enlarge
      Amlogic @ 2.02 GHz – Click to Enlarge
      MIBOX3 board name: once – Click to Enlarge
      While reviewing
      So not all apps are available due to the restrictions of Android TV and Google necessitating the apps be remote friendly. But you might run into a situation where you want to side load. If you have a air mouse or some other hid device connected it’s not a big deal. In order for to launch them in the past you loaded sideload launcher from the play store, It allows you to see all apps regardless if they are Android TV optimized. It works and is pretty easy. While reviewing I ran across a pretty neat app. TV App Repo. It makes sideloading even better. What it does is create a small app that is basically a shortcut to your side loaded non Android TV app. Now all the apps can be launched from main screen without navigating to the sideload launcher sub menu. It worked on the few I tested. On the community addition, there are a few apps that it hosts one of which was Amazon Prime video. But I didn’t have luck getting videos to play other than trailers. Final Thoughts
      I wasn’t going to perform any benchmarking on this box. I don’t think that it is relevant. But I knew it would be crucified. This box was in my opinion built to consume media and I think it does it very well. All the streaming media apps worked great. The only drawback is that HDMI passthrough and auto framerate switching did not work consistently enough in Kodi or Plex. Streaming from HDHomerun works well even over WiFi. Amazon Prime Video is missing from this box. I did try some other methods to watch and only was able to cast from a web browser successfully.
      During testing I didn’t use Kodi much and stuck with the main streaming apps that are optimized for Android TV. I hope Koying, the maintainer of SPMC, a fork of Kodi, brings some love to the Mi Box in the near future or even the Kodi team.
      If you’re not an audiophile this will make a great box to stream with and hopefully save some money. If you are an Audiophile the Mi Box complements the Nvidia shield on other TV’s where surrounds sound doesn’t matter.
      Source: CNXSoft
        I would like to buy the xiaomi mi 4k, with this cheap scrap tv boxes i have only problems. Most do not support automatic framerate switching and it is also not the real Android TV installed.
        What is the situation with the xiaomi? Is automatic framerate switching supported with android tv?
          No.. current firmware does not support it. If it's that important to you, get a Wetek HUB or of course the Nvidia Shield.
