help with mk809 iii, identify version and unbrick
    hi! i just got one of this as a gift, i already flash rom with normal phone but i've got no idea about tv stick, can you guys help me with this? when i connect the tv stick to the tv nothing happen, like i've connected nothing, so i guess it's bricked? the red light is on.. and wich model is mine? on the outside box it says mk 809 iii but i've read there's more than one version, right? thanks and sorry for my english
    You may only view thumbnails in this gallery. This gallery has 7 photos.
    Hello and Welcome to FT !
    For Flashing a TV Stick please read this:
    There are also the Links inside for the needed Tools.
    A Custom Rom for your Device you find here:
    Regards
    Neomode
      thank you! so my tvstick is a mk802iv? my box say it's a mk809iii
        Same Hardware of these Sticks.
        that's the way you can flash it.
        Regards
        Neomode
          windows 10 is okay? or windows 7 is better for this process?
            Yes Windows 10 should work.
            sometimes the driver signature can be the problem in windows 10.
            Regards
            Neomode
              wich file should i select here? i have to flash every file with the same process?
                First select the Tab Download Image.
                Then you select Boot Loader Parameter etc Then you burn it.
                Neomode
                  done, like in the picture, when i connect the tvstick to the tv nothing happen, no video no audio, with both micro usb
                  edit 19.07: it was the wrong screenshoot
                    Try that Rom:
                    Neomode
                      another question, when i connect the tvstick to the pc i have to use the side entrance, when i connect it to the tv wich micro usb should i use?
                        btw nothing even with this firmware, still black screen and no audio, with both micro usb. there's a software to check if it's bricked or not working?
                          bump please
                            nothing? it's dead?
                              bump
