LIST OF WHAT YOU NEED
1: 2.4Ghz Antenna & Pigtail
2: Soldering Iron and rosin core solder for electronics
3: Drill or Dremel to make hole
4: Needle nose pliers to fasten pigtail to box
5: Magnifying glass or bifocal glasses, Very small area your soldering and wires are tiny
6: Razor blade to trim antenna wire.
7: Small jewelers tool screwdriver or like object to pry open box
Bottom cover rear of box you will see a notch, This is where to pry it open.
INSTRUCTIONS:
1: Carefully pry open box from bottom starting at rear center where you see the little notch.
2: Remove 4 small Philips screws that hold PCB to case, Peel off internal antenna & remove PCB.
3: Drill hole in left side of box as seen in photos where the notch is on the PCB
4: Carefully Desolder internal antenna wire
5: Strip and solder pigtail wires to PCB
6: Insert & fasten pigtail to box
7: Reassemble
NOTE:
YOU MAY HAVE TO TRIM SOME PLASTIC FROM BOTTOM COVER WHERE IT MEETS UP WITH ANTENNA MOUNT TO GET THE COVER TO SNAP INTO PLACE.
SHITTY INTERNAL ANTENNA
PIGTAIL INSERTED IN LEFT SIDE OF BOX
AFTER SOLDERING TO BOARD
FINISHED PRODUCT
WIFI SCAN BEFORE MOD
WIFI SCAN AFTER MOD
I USED A 2.4 Ghz ANTENNA & PIGTAIL I ALREADY HAD ON HAND FROM ANOTHER OLDER BOX FOR TESTING, JUST MAKE SURE THE ONE YOU USE IS FOR 2.4 Ghz & NOT 5 Ghz
Derek.
