YOKA KB2 PRO Android 6.0 TV Box 3GB DDR4 + 32GB eMMC
Hi I am new to this forum. Has anyone tried this box yet? I've just purchased this box, specs are pretty good compared to others. I have M9S Leelbox and it's not bad. Giving it away to my friend and got this one for me. I also purchased Alfawise S92 incase this is no good, reviews were great. I was looking at Alfawise H96 pro+ as well but decided to go with this one.
I received the box yesterday and it runs really well. WIFI speeds are amazing, no need for wired now. Benchmarks with Antutu was around 42000. No green flashes. Kodi was version 17 which i probably will remove, I like version 16 better. I am going to try connecting my wireless xbox controller see if it works, only thing I can not get working yet. Alfawise s92 box was good as well, it was similar to M9S box.
Thanks To Gearbest today we can have a look at the Yoka KB2PRO S912 3/32GB DDR, Gig Lan, Dual WiFi
Typical Packing
Remote
Underside and View of Ram Samsung
Top Side View with Lid
eMMC
Wifi Chip
Ethernet Chip
Base Plate
SO what we have Is Pretty much the same as other of these Make and Breed except we have the DDR4 Ram so there will be a slight improvement but nothing MInd Blowing
More to Come
Now for a look at How things are running on the Yoka KB2PRO S912 3/32GB DDR, Gig Lan, Dual WiFi
All fired up and ready to, much the same UI and other Yoka Media Players.
No Junk in the Trunk and unit does have root.
Testing both WiFi and Ethernet speeds Good at this location.
App store all good and loaded the usual testers in Quick time.
This Is usually a good test point click a tonne of apps on Google play and see how they load and how the box handles it all to easy with this DDR4 ram.
Temps SO far testing Good idle Low 50c, under the punp low~Mid 60c so about average for this type of unit.
No Mod has been done as yet.
UI-Same
Apps Installed
System:
Couple of added feature good to see:
Turn off the Boot Animation if it annoys.
DRM Info:
Ram Truth:
Storage Truth:
A1 Ram Benchtest Good Speeds/timings:
Vellemo Benmchmark:
Antutu:
CPU Z Information:
Easy to see performance so far pretty good and no major problems every thing pretty smooth
Some Netflix and Local Plex testing all easy and good for this type of Media Player.
Gearbest
There are currently 1932 users online. 3 members and 1929 guests.
