Auto Frame Rate Fix APK on S905x and S912 firmware
Sadly it does not work for meI have a NEXBOX A95X S905X 2GB+16GB Android 6.0 player. I tried Kodi 17 and SPMC. After restart Fix Applied notification is OK, but playing movies still 60Hz both Kodi and SPMC
In the disp_cap file contains the 1080p 24hz resolution so its not empty. I tried the Kodi.AmLogic.script.frequency.switcher 2.0.2 and still... 60Hz grrr... whats happening?!
Originally posted by Krisztian5 View PostSadly it does not work for meI have a NEXBOX A95X S905X 2GB+16GB Android 6.0 player. I tried Kodi 17 and SPMC. After restart Fix Applied notification is OK, but playing movies still 60Hz both Kodi and SPMC
Originally posted by Krisztian5 View PostYes the "Adjust Display Refresh Rate" set to Always in both app.
Interesting thing the resolution settings in Kodi and SPMC is greyed out
My TV: LG 32LF5610
Originally posted by nic029 View Posthello,
I have found and use an addon for Kodi for adjust frame rate at https://github.com/jeff2900/Kodi.AmL...tcher/releases
Originally posted by zamakhshary View Postwhy it doesnt work on GT1 ultimate and what is the alternative
Installing supersu has fixed my problem, the frame-rate is changing great now.
My only problem now is stopping the frame-rate change notification on my Samsung TV from showing every time, I have checked the setup for a way to turn it off, But i cannot see a way to do it.
I have an Samsung UE55F6320AKXXU.
John.
Screen shot is from "Ghost in the Shell: Stand Alone Complex" 2002
I take it that you also turned on auto framerate adjust in Kodi and SPMC too?
There are currently 1059 users online. 0 members and 1059 guests.
