So here goes the first unofficial ROM (thanks to Ukrainen@xda-developers) for Penta IS709C. Its a Jellybean 4.2.2. and even though is still in very early phase of testing, sharing it for others to try. I am not a developer but if you find any issues, please let me know and I'll forward them to the developer...
Use it at your own risk. All your existing data will be lost and I am not responsible if you brick your device (however will try and help you bring it back to the state you purchased it in, but no guarantees)
This is what you need to do:
1) Download the zip file from here: https://docs.google.com/file/d/0B5T-...it?usp=sharing
2) Extract it to your desktop or any other loaction on your PC/ Desktop you prefer
3) In the folder 'CustomRom4.2.2forPentaIS709C', right click on RKtool.exe and click run as administrator (on Windows 7, figure out your self for any other OS)
4) Put your tab in flash mode [switch it off, press and hold the menu button (middle button of the 3 buttons below the camera) and then insert the usb cable already connected to your PC]
5) Your PC will install its drivers automatically, it auto driver installation fails...go to device manager on your PC and you'll find your device in other devices. Right click on it, click on update driver software, click browse my computer...and then point to the drivers section of folder 'CustomRom4.2.2forPentaIS709C'.
6) After driver update Click on EraseIDB of RKtool.exe window and wait for it to complete
7) Click on Run (You need not do anything after this step, just sit and enjoy)
8) Your tab will reboot once the above step is completed and the recovery system will do some formatting.
9) It will reboot once again and within next 5-10 min you'll have a working Android 4.2.2. on your PentaIS709C.
If you want CWM Recovery (thanks to Fun_), after completion of above steps (i.e. update to 4.2.2) download the zip file from here: https://docs.google.com/file/d/0B5T-...it?usp=sharing, unzip it, put yoour tab in flash mode, open RKtool.exe, uncheck all the boxes except for recovery, point the path for recovery to the recovery.img of unzipped CWM folder and click run. Your tab will reboot after completion, do a manual reboot if tab is hanged at boot logo for more than 5 minutes and you'll have the CWM recovery on your device.
Enjoy....
Known issues:
1) Camera is not working....
2) With the tab in portrait mode, if we touch and hold any icon, the screen gets inverted...
I deserve a thanks if I've helped you ever....
All the best
