NEXBOX A95X s905x not playing nice with Amlogic customization tool
    Hey guys,
    I'm trying to play around with debloating the stock NEXBOX a95x s905x 1g/8g firmware with amlogic customization tool, If I remove any app found in Level2/system/app and try to repack the firmware.. it builds it no problem. but when I flash my custom rom with usb burning tool. it flashes %100 but after fresh boot the box will only boot to recovery?
    can anyone lend a hand on what i'm doing wrong...
    I have already done debloated rom for sunvile t95 without a problem.. but for whatever reason I can't make one for the NEXBOX
    Read this : http://freaktab.com/forum/tv-player-...2-0-8-and-root
      Another way that an issue like this can occur is when you manually remove the folder and APK instead of doing it on the System APK tab in the tool.
        Damn how did I miss that.. Thanks both of you for the help. I appreciate your help..
          But you can not do that because you can not unpack the system apk without it crashing from everything I have tried. If I select that last check box before unpacking it spins and crashes. I have tried previous versions but am currently using Customization 2.0.10 with Amlogic S905X. Is there a fix or training I missed?
            dont unpack the system apk.
            you can still access the apk files.
            unpacking system.apk is for editing the actual APK itself, this fails on Marshmallow roms because of issues with the apktool within customization tool.
            from what youve posted, you dont need to unpack system.apk. untick that option in customization tool
            also 7.0+ (Nougat) roms dont work on Customisation tool. issues with kernel and repacking
