TX3 pro bricked
Originally posted by Pakbit View PostI solved, the pins for the reset are those 29-30 but no they understood very well what they were, after all afternoon on "google" I found the right match ...
I have a box with a Foresee chip too and I am trying to find a way to reset it. The problem is that I don't see any pins besides the chip. Do you know what I should do?
I attached pics here.
Thank you!
Originally posted by besik View PostI had another problem. I updated my tv box with the sd card and after the update the box rebooted, but I got a black screen and glowing red led. It did not turned on or responded to the remote. The computer also did not recognize it. I opened the tv box, short two contacts of the flash memory (i don´t remember which ones exactly that were), connected it to the computer and it worked. I updated the tv box with USB Burning Tool and took this firmware https://mega.nz/#!N8dRVTqB!iTJfPvnne...vtDG9A6dwcpbXA, because I have NANYA DDR. To find out what ddr you have, you can open the tv box or check the serial number. When the serial number include the letters NY, than you have NANYA DDR.
i follow Pakbit clue for the pin and successfully unbricked my friend TX3pro that have the same emmc like besik have 'kingston" and NANYA DDR off course
before that i tried with the firmware i found in geekbuying blog but it make stuck at 4% with 0x10908002 error code
and after i try with besik firmware, it success, and now run well like before
Originally posted by Dumdum View PostI had the same problem. Bricked my tx3 trying custom firmware. The nanya firmware worked to unbrick. I still cannot install any other rom but this one. Other roms give me unknown error in usb burning tool. Can anyone explain to me why?
Gosh, why did you even need to disassemble your box when your box bricked. I've encountered many times like your situation having a hard bricked box with red light appearing but black screen on the TV.
When you're in this situation, don't dig your grave deeper by attempting another manufacturer's signed ROMs. Get your box's manufacturer's latest official stock ROM to make a recovery SD card instead.
Originally posted by xanadu89897 View Post
Get the correct official ROM image from Tanix themselves, confirm with them then use this method to revive your box:
here is the TX3 Pro Nanya firmwares but they require baidu netdisk and account
it has quite a few other models!! ( i found a way to download them fast from baidu)
https://sztopleo.en.alibaba.com/custom_page_1/Technical_Support.html
so i put them in a fast webstorage
https://www.mediafire.com/file/qnqi6...61222.img/file
https://www.mediafire.com/file/a37fe...70105.img/file
SD Card https://www.mediafire.com/file/2umg4qf7njwxd9n/TX3pro-nyddr.zip/file
and its definitely working!
i had error at %7 formatting.. after i reflowed all the chips with kester flux and hot air i was able to flash with 2.1.2 usb flash and boots!!
(no need to short pins)
with 2 minute logo screen first time.Last edited by LatinmcG; 19 January 2020, 12:24.
Originally posted by wong View Post
thanks besik for your firmware
Originally posted by CHETO View Post
Would there be a way to upload it again? mega link no longer exists.
There are currently 1875 users online. 0 members and 1875 guests.
