Seems that the firmware or kernal doesnt have all controller modules installed. Can someone help me with the steps to installing extra ko files? Im knew to all this
# Copyright (C) 2011 The Android Open Source Project # # Licensed under the Apache License, Version 2.0 (the "License"); # you may not use this file except in compliance with the License. # You may obtain a copy of the License at # # http://www.apache.org/licenses/LICENSE-2.0 # # Unless required by applicable law or agreed to in writing, software # distributed under the License is distributed on an "AS IS" BASIS, # WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. # See the License for the specific language governing permissions and # limitations under the License. # # DragonRise Inc. SNES Pad (i made this up, you can rename it if you have a model number or something, it's just for documentation) # key 0x131 BUTTON_A key 0x132 BUTTON_B key 0x130 BUTTON_X key 0x133 BUTTON_Y key 0x134 BUTTON_L1 key 0x135 BUTTON_R1 key 0x136 BUTTON_L2 key 0x137 BUTTON_R2 key 0x138 BUTTON_SELECT key 0x139 BUTTON_START key 0x13a BUTTON_THUMBL key 0x13b BUTTON_THUMBR axis 0x00 X axis 0x01 Y axis 0x02 Z axis 0x05 RZ axis 0x10 HAT_X axis 0x11 HAT_Y
su mount -o remount rw /system cd /storage/emulated/legacy/ cp Vendor_0079_Product_0011.kl /system/usr/keylayout chmod 644 /system/usr/keylayout/Vendor_0079_Product_0011.kl reboot
There are currently 2944 users online. 0 members and 2944 guests.
