Forthcoming Ugoos UT5 - Based On The RK3399.....
    From the Ugoos blog, their coming RK3399.
    Here is a render of a future housing case for Ugoos UT5...
    Official information about next Brand TV Box based with brand new RK3399 chipset
    Specs:
    Operation System: Android 6.0
    Languages: English...Multi-Language support
    Chipset: RK3399 28nm Dual Core Cortex-A72 + Quad Core Cortex-A53
    GPU: Mali860 MP4 OpenGL ES1.1/2.0/3.0/3.1, OpenVG1.1, OpenCL, DX11
    Supports AFBC
    SDRAM: DDRIII-2133 4G
    Nand Flash: 32GB Nand Flash (optional: 16/32/64GB)
    Storage Extension: Support SATA, 2.5 Inch or 3.5 Inch, Max 8TB
    MicroSD (TF) card, Max to 256GB
    Network: AP6359S, 2.4GHz*2/5GHz*2 Wi-Fi 802.11 a/b/g/n and 802.11 AC.
    Support LAN 10M/100M/1000M Base-T
    Bluetooth: Support BT 4.2 Module
    Power Supply: DC 12V/3A
    Interfaces:
    HDMI
    1 x HDMI (A type Female), HDMI2.0, Support 4Kx2K decode output 60fps
    USB Ports
    USB3.0 x 1 Type-A x 1 USB2.0 x 2
    Type-C Support appointed VR sets
    Fiber-optical Output 1 x SPDIF
    Card Reader 1 x TF
    SATA 1 x SATA
    Network port 1 x RJ45
    Power Supply 1 x DC Jack
    Antenna Wi-Fi external 5 dB antenna *3
    Media Parameters:
    Video Decoder H.265 4096*2304 60fps
    H.264 4096*2304 60fps
    VP9 4096*2304 60fps
    MPG4 1920*1080 60fps
    Full video format decoding support:
    Formats MPEG-1, MPEG-2, MPEG-4, H.263, H.264, AVS, VC-1, RV, VP6/VP8, Sorenson Spark, MVC
    Video Encoder H.264, MOV, 3GP
    Video Output HDMI output: Support 4Kx2K (4096x2304) @60HZ HDR
    H.265 Data Rate
    Up to 60fps.
    Software Extension Support Play market & APK install.
    Protocols:
    Support DLNA, Miracast Protocol, Support DRM requirement, airplay, Audio push.
    Certificates: CE, RoHs.
    New RockChip3399 gives incredible abilities for mobile platforms and mini PC devices. Rockchip has unveiled the RK3399 processor back at CES 2016 and this SoC now becomes a heart for new Chromebooks performed by ASUS.
    As you can see from the specs this is our first Branded TV Box with SATA port and HDD holder. Device will able to connect 2.5 and 3.5 inch hard drives.
    Hi to all ,
    do they really want to use this case for the UT5 , i already saw it somewhere else , other Tv Box.
    nice Day
    gefattern
      Its funky metal feet bent maybe some expansive vents underside for super air flow. We get to know more as they show more.
        Yes and Groovy, needs to be Piano Black...
          I think it may look better in an actual photo than it does in the render. If the subject of the render is basically a rectangular box, then the render looks "out of square" to me, so likely doesn't do the actual case justice.
          But a function-over-form guy here, wouldn't bother me if it looked like a coconut. At least as long as the coconut still had three antenna and SATA dock.
          +1 to ample ventilation and +1 to piano black, both good things.
            There is also a fan at the back or a fan inside with a fan opening at the back for airflow to escape, I'm not sure which one of the 2 exactly.
              Fan, another good thing.
              I saw the Firefly 3399 boasts GPU acceleration in Linux, might I assume Ugoos will release a version for the UT5.
