BEELINK MINI MX-G 2GB [NEOMODE CUSTOM ROM]
    Hi to all, here is a New Neomode Custom Rom for the MINI MX-G 2GB from Beelink.
    I have Tweaked the Rom for Speed and Performance.
    What is Working?
    - Everything ;-)
    Is the Rom Rooted?
    - Yes it is
    What Software comes with it?
    - FTMC
    - MiXplorer File Explorer
    - NetFlix
    - AdAway
    - Amazon Video
    - Petrus Reboot
    - MX Player
    I removed all the unneeded Apps from the Rom.
    The Rom is spoofed as Nexus 10 Device.
    Also the Google AndroidTV Remonte Apk from Playstore is Working !
    USB Touchscreen Support is Build in !
    Download here:
    Is your rom will be compatible with M8S II ? (A905X)
      It's for a S905 not a S905X processor like yours.
        shit !
        Do you know if it is possible to have a rom for S905X with touchscreen build in ?
          Yes, it is possible ;-)
          Tell me what Touchscreen?
          Neomode
            thanks...
            I have this touchscreen : AOC 23.6" LED Tactile - i2472Pwhut
              Do you think that it is compatible with this touchscreen ?
                Yes i think so, l build the needed Modules for you !
                Neomode
                  Thanks you very much... Which version of android do you have ?
                  If android Marshmallow with TWRP and Xposed may be installed, it will be perfect
                    S905X is always Android 6.
                    So I will build the modules for that System.
                    Neomode
                      Short instruction how to install?
                      Edit:
                      1) Unzip IMG file.
                      2) Burn with USB Burn tool using USB cable and tooth pick method.
                      Thanks for your work.
                      How can I remove apps shortcut from bottom bar?
                        Thanks for your work!
                        Will it work on a Beelink Minimxiii s905, 2gb/16 gb?
                          Just one question : if I install the rom that your are building, if I want to update, I need to recompile the firmware or OTA update will work (without lose touchescreen compatibility)?
                            Hola
                            Do you have some news about the build
                            Thank
                              Neomode are you there ?
