PIPO M9 Max Stuck At Boot Screen And Reset Does Not Help
    Hello,
    After upgrading to KitKat 4.2.2 and using this tablet for a couple of years it recently was no longer able to boot.
    It is stuck in "Android" boot screen and trying to reset it with metal pin does not help.
    What would be your suggested steps to fix this?
    Hi TechnicGeek ,
    the only way to solve this is flashing the Firmware new.
    have a nice Day
    gefattern
      @gefattern Do you know what could have caused this?
        Hi TechincGeek ,
        No , you really must flash it new , or did you try to boot to Recovery , wiped all the caches even the Dalvik and reboot , thats the only thing that maybe ??? helps ???
        What kind of Recovery u have on your Device ???
        The M9Max is already an old one like my old M9Pro.Do you really used the right Rom there are differnt Models with one and two Nands , if i remember it good.
        have a nice Day
        gefattern
          I have not yet tried to boot to recovery. This tablet does not have physical volume up and down controls and I forgot how to access recovery. The ROM is a custom one - Riley's 4.2 I think or 2.6 with Android KitKat 4.2.2
            Hi TechnicGeek ,
            what about Power and Reset hole at the same Time to boot to Recovery ???
            Is it still recognised by Pc ??? Best is to flash new.
            have a nice Day
            gefattern
              In Recovery Mode I can't activate menu with commands:
              Tried RK Batch Tool v1.7 for reflash using ROM from ArcTablet: http://www.arctablet.com/blog/forum/...ware-20140604/
              It failed and received fail error:
                Hi TechnicGeek ,
                did u use Restore or Upgrade for this Flash ??? Try it with Restore.
                Did you download the Rom new ? or was it already stored on your Pc ?
                Maybe the download was not Error free ?
                I think there are two different M9 Models , with one Nand and with two Nands , if i remember it good.
                look this Hint on Top of the Page :
                http://freaktab.com/forum/tablet-sup...rom-2-6-kitkat
                Did you tried another Rom ?
                have a nice Day
                gefattern
                  Hello gefattern,
                  1. I used Restore option in RK Batch Tool v1.7
                  2. Downloaded new ROM and it extracted successfully. No errors that I can recall...
                  3. Mine has 2 NAND chips and this is Riley's ROM that I upgraded to from stock ROM: http://freaktab.com/forum/tablet-sup...x-rileyrom-2-5
                  4. I did not try different ROM. Should I try the one you posted in reply? It will be Riley's again.
                    Hi TechincGeek ,
                    if the Rom u used is really for the "two Nand" Version of M9Max ??? try Upgrade and did you use this Rom before ???
                    You can try the Rom i linked , if you want and i hope it helps you to get your M9max back to live.
                    Report the Results
                    have a nice Day
                    gefattern
                      Last time it worked it had RileyROM 2.5.3 installed. Suddenly it stopped working and was stuck at boot logo. Tried downloading KitKat 4.4.2 Kasty firmware and after process almost complete had "Download firmware fail" message.
                      I wanted to flash with RileyROM 2.6.4 and using ROM Flash Tool v1.37 I have reached the stage with NAND testing. It did not fail but it kept counting memory over and over when it was close to 16384, every time restarting count. I had to disconnect and after reconnecting and restarting flashing process it would no longer reach NAND testing stage. It would now be at lower format stage where same thing would be happening as with NAND but now it's with formatting:
                      Click image for larger version  Name:	lower-format-fail.jpg Views:	2 Size:	229.2 KB ID:	622498
                      I tried RK Batch Tool v1.7 and reconnected cable. The tablet would now disconnect after every 10 seconds and reconnect back thus interrupting Test Device stage but
                      even if it was at 97%, it would resume from that point. It was never 100% and it started all over:
                      Click image for larger version  Name:	test-device-restarting.jpg Views:	1 Size:	204.7 KB ID:	622494
                      If I released power button I would get this error:
                      Click image for larger version  Name:	test-device-fail.jpg Views:	5 Size:	199.5 KB ID:	622496
