T95X Clone Red Light Of Death afer TWRP - Help?
    Hello everyone!
    I got a clone T95X box, on the info it says it's a Nexbox A95X 1GB/8GB. I installed TWRP then booted into it, started testing and erased all partitions (yeah dumb) on the advanced wipe screen.
    I had made a backup“of all the partitions to an external drive (I still have it) before I did this so I thought "ok no big deal" and went to grab a drink before I restored it. When I came back someone or one of the dogs had pulled or kicked the power cord and it was turned off!
    Now when I power it on all I get is a red light, no image no nothing.
    What I tried so far:
    1- Magic SDcard method with cyx_NEXBOX-A95X_S905X_8189etv_8g1g_kodi_addons_161104_SD_USB firmware -> nothing
    2- USB Burning Tool 2.0.8 -> device doesn't show up, no matter what I do or how I connect it to the USB male to male cable. Tried monitoring the device manager on windows 10 x64 but when I plug the cable on absolutely nothing happens.
    3- http://freaktab.com/forum/tv-player-...962#post306962 tried this method using the uboot.bin image from the cyx fimrware above. Nothing happens.
    I have no clue of which pins to short on the nand (it's a Eudar EMS1ASCBT1FC008 module) so if anyone knows the pins for this one, PLEASE share!
    I've run out of things to try, can you guys help me out reviving this box?
    Thanks a LOT for the help!!!
    Ok some new info I was able to find out, seems its a clone of the sunvell T95X S905x instead. The port order is the same, its just flipped upside down. It says 905X_V1.2 20160621 3416 on the board. Any clues?
      I can't help sadly, but I do have the same problem. Not sure what caused the problem though, didn't touch my Sunvell T95X while flashing another ROM.
      Tried USB Burning tool as well, but my device is also not recognised. SD Bootcard maker didn't help either.
        A photo of the nan chip may help us point you to correct pins.
            looks just like mine, but my nand is another brand.
            Couldn't find which pins to short, if anyone could point them out would be of immense help!
            You may only view thumbnails in this gallery. This gallery has 5 photos.
              What happens if you short the wrong pins? Is trial and error a solution?
                I tried them all and nothing happened, still getting the red light when I plug it into power
                  Right, I also tried to shorten pins randomly, didn't work.
                    Let's hope scooter2014 can shed some light on our nand chips!
                      Sorry Lost this post. Checking now forsee I have so think that one we get.
                      http://freaktab.com/filedata/fetch?i...0&d=1472285144
                        Thank you!
                        So which steps do I need to take now?
                        Do I need to flash an u-boot image on an SD card using Amlogic Bootcard maker, then short NAND, power on box while holding recovery?
                        So I need to shorten the PINs permanently or for the whole process?
                          scooter do you think it's the same pins for my eudar?
                            Originally posted by hummel95 View Post
                            Thank you!
                            try the male to male usb cable flashing with usb burning tool method, should work!
                              The pins are the correct ones. After shorting the pins, the device is recognized in USB burning tool.
                              When trying to flash aml upgrade package, the process stops at 2 percent. I will do more research, I read somewhere about this error.
