M8S [Clone] Allwinner H3 firmware need
    Hi. I cannot find a rom for M8S with Allwinner H3 chipset. I try firmware frrom Beelink X2 because it is same but flashing not starts. I tried to boot with that firmware from SD Card and it works, but I can't flash to device. When I insert PhoenixCard SD in slot, device stuck on green progress bar and not start flashing.
    Model: Mbox3 (dolphin_fvd_p1)
    Hardware: sun8i
    Android Version: 4.4.2
    Firmware Version: v1.0.1
    Kernel Version:
    3.4.39
    chdy@host #3
    Build number: KOT49H.20160504 test-keys
    Bootloader version: unknown
    I need to reflash this box, because I cannot do a factory reset (device only reboots or stuck without blue/red light), cannot uninstall any app (app unistalls but restores on reboot), and cannot run some applications. Play Store, YouTube, Kodi applications not work. I really need this firmware. I was looking, but I could not find. Do this can be problem with memory?
    Did you solve the problem? I have the same device, it wont boot, cannot find any firmware.
      No. I returned device back to retailer and they replaced it.
        So, you have the working device? Can you, please, use TWRP recovery and make the dump of your working firmware and post it here?
        Thanks in advance!
          There is no TWRP for this box and it is not even rooted, so I cannot dump a firmware.
          Sorry for late reply.
            please someone with a link?
              have you found a firmware ?
                Here
                ​​​​​https://www.cubot.net/support/firmwa...-pc-flash.html
