Right..... I have been using an mx android box the mark 1 for around a year and a half and it has been absolutely brilliant, it does everything I could possibly want from a tv box. Problem is I turned it on the other night in the same way I have done every night for the past 18 months and to my horror nothing came up on the screen as if the hdmi cable wasn't plugged in. I ensured hdmi was plugged in correctly also tried plugging in through scart and hdmi also with no success, the box seems like it's all working because it responds to the remote but it seems like the box isn't sending a signal output to the tv. All my cables are fine because I have used them with other media devices. Any help would be much appreciated.
need expert advice plz😧
I apologise if I am posting this in the wrong place (newbie).
Right..... I have been using an mx android box the mark 1 for around a year and a half and it has been absolutely brilliant, it does everything I could possibly want from a tv box. Problem is I turned it on the other night in the same way I have done every night for the past 18 months and to my horror nothing came up on the screen as if the hdmi cable wasn't plugged in. I ensured hdmi was plugged in correctly also tried plugging in through scart and hdmi also with no success, the box seems like it's all working because it responds to the remote but it seems like the box isn't sending a signal output to the tv. All my cables are fine because I have used them with other media devices. Any help would be much appreciated.Tags: None
There are currently 2246 users online. 1 members and 2245 guests.
