Specifications
•Essentials | ||
Status | Launched | |
Launch Date | January , 2017 | |
Product model | GT1Ultimate | |
Dimension | 96*96*16mm | |
Processor Number | Amlogic S912 | |
•System Config | ||
OS | Android 6.0 | |
Language | Multi -language | |
CPU | Amlogic S912 Octa Core ARM Cortex-A53 CPU up to 2GHz(DVFS) | |
GPU | ARM Mali-T820MP3 GPU up to 750MHz(DVFS) | |
RAM | DDR43GB | |
ROM | Onboard eMMC Flash 32GB | |
Ethernet | 1000Mbps LAN | |
WIFI | IEEE 802.11a/b/g/n/ac2.4G+5.8G | |
BT | BT 4.0 | |
Antenna | Built-in antenna for WIFI | |
Expand Memory | Micro SD Card (Maximum support 32GB) |
• Button & Ports | |||
Button | Not Power ButtonConnecting the power suppliesautomated system operation | ||
DC-in | 1*DC in Port | ||
USB2.0 | 2* Standard USB Port | ||
HD | 1*HD Type Port | ||
RJ45 | 1*RJ45 (1000Mbps network connection) | ||
SPDIF | 1*S/SPDIF | ||
TF Card Slot | 1* Micro SD card slot | ||
Power LED | 1* power LED with two - color | ||
•Powerful codec capabilities | |||
UHD 4K 60fps HW decoding, supports multiple formats including H.265 10-bit, H.264 and AVS+ FHD 1080p 60fps HW encoding, supports H.264 |
•Video/Picture Decoding | |||
VP9-10 Profile-2 up to 4Kx2K@60fps H.265 HEVC [email protected] up to 4Kx2K@60fps H.264 AVC [email protected] up to 4Kx2K@30fps H.264 MVC up to 1080P@60fps MPEG-4 ASP@L5 up to 1080P @60fps WMV/VC-1 SP/MP/AP up to 1080P@60fps AVS-P16(AVS+)/AVS-P2 JiZhun Profile up to l080P@60fps |
