Manufacturer: Amlogic
Model: MBOX
Brand: Amlogic
Board: p212
Device: p212
Hardware: amlogic
Platform: gxl
Product: p212
Standard number: 0123456789abcdef
Installed RAM: 2 GB
Whole memory: 1775 mb
Available memory: 1098 mb
Internal whole mass memory: 4870 mb
Boarder of free mass memories: 3614 mb
More externally whole mass memory: 59.07 GB
More externally free mass memory: 15.28 GB
Core architecture: 4x ARM Cortex-A53 2016 MHz
Instruction set: 64 bits of ARM
CPU check: r0p4
CPU cores: 4
CPU tact area: 100 - 2016 MHz
Core 1 tact: 2000 MHz
Core 2 tacts: 2000 MHz
Core 3 tacts: 2000 MHz
Core 4 tacts: 2000 MHz
CPU extent of utilisation: 7%
Scaling regulator: hotplug
Supported Abitur: armeabi-v7a, arm Abitur
Supported 32 bits of Abitur: armeabi-v7a, arm Abitur
FEED: Supported
NEON: Supports
SHA1: Supports
SHA2: Supports
Screen resolution: In 1920 × in 1080
xdpi / ydpi: 160 / 160 dpi
GPU Manufacturer: ARM
GPU Renderer: Mali 450 tommy gun
Revitalisation rate: 60 hertz
Standard adjustment: Horizontal format
OpenGL IT version: 2.0
GPU Version: OpenGL IT 2.0
Android version: 6.0.1 (marshmallow)
API Level: 23
Android Security patch level: 2016-06-01
Rooted device: Yes
Android ID: c730f8978e36c748
Build ID: T5X10004
Code name: REL
Fingerprint: Amlogic/p212/p212:6.0.1/MHC19J/20160926:user/test-keys
Increasingly: 20160926
Java run time version: Android run time 0.9
Java version VM: ART 2/1/0
Java VM Heap Size: 192 mb
Kernel architecture: armv8l
Kernel version: 3.14.29 (it01@ubuntu) (gcc version 4.9.2 20140904 (prerelease) (cross tool-NG linaro-1.13.1-4.9-2014.09 - Linaro GCC 4.9-2014.09)) #2 SMP PREEMPT Thu Sep 22-9:42:20 PM CST 2016
Of day: test keys
Type: user
OpenSSL version: BoringSSL
ZLib Version: 1/2/8
Version ICU CLDR: 27/0/1
ICU Library version: 55.1
ICU University code version: 7.0
Android language: In German (Germany)
Opposed time zone: Central European standard time (UTC+01:00)
