Now I'll start with the problems I've managed to fix. On first boot I installed the basics that I require from the box: Netflix, Amazon Prime Video and a proper YouTube app not the incredibly out of date YouTube for android TV. Who wants to guess at how many of these worked?
If your answer was Zero you would be correct, Netflix threw up some generic connection error which after several data, cache clears, factory resets and reinstalls seems to have sorted itself. Likewise for Amazon Prime.
Now the biggest issue I have and this is a deal breaker for me is I can't get Youtube to play at all the app loads fine all the Thumbnails populate but no matter what video you select the pinwheel just spins and the video never loads. I've trawled through forums and Google searches which is a minefield if you type YouTube playback problems or any other related search string I've tried every obvious fix I've seen, Factory resets, data and cache clears, older versions of the YouTube app, nothing fixes it.
So this is where you guys come in. I'm hoping someone out there has experienced this issues and it's a very obvious fix that I've not came across yet.
Oh and I'm also running the latest manufacturer Videostrong firmware: 20161209 and it's not my internet connection.
So thanks in advance and hopefully together we can solve this, if not the box is going back.
