please help i have a hd18 v2.22 and i cant seam to be able to find the right firmware
    can some one please help , im looking for the right files to flash my mx box hd18 v2.22
    this was on it
    mbx g18ref
    4.2.2
    kernel version 3.0.50
    tue aug 20 19:01:54 cst 2013
    jdq39.20130820
    i tried to flash linux and now i cant get the box to boot
    last thing i did was i created a sd card with
    aml_autoscript
    factory_update_param
    g18ref-ota-20141022
    u-boot.bin
    recovery
    uImage_recovery
    if i short the pins out on the nan chip and run the above it will say its installed but the box will not boot when rebooted
    also
    i got amlogic burning rom setup and i have the cable a-a but cant find the config file needed or the right flash
    i must be doing some thing wrong or the files i have are corrupt can some one please help
