ADB via USB?
Edit build.prop with the following and you get both USB and Wifi ADB access. By doing this you loose the upper USB port. For idk what reason the MTP/OTG will stop functioning on that port after... It neither can be usef for peripherals.
Code:persist.adb.notify=0 persist.service.usbadb=1 persist.service.adb.enable=1 persist.service.debuggable=1 persist.sys.usb.config=mtp,adb service.adb.tcp.port=5555
There are currently 1489 users online. 2 members and 1487 guests.
