Linking SPMC to Smart TV Box Launcher screen?
This should give you all the information that you need to install.
https://ibotpeaches.github.io/Apktool/R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
I haven't tested it so make sure you backup SunvellWin8Launcher.apk and best to install another launcher (any is fine) so as to have a working launcher just in case.
Extract classes.dex from the uploaded zip file. classes.zip
Copy 'SunvellWin8Launcher.apk' ('/system/app/SunvellWin8Launcher/') to your PC and open with WinRAR or something similar.
Delete 'classes.dex'
Drag the new 'classes.dex' to the same location as the one you just deleted (compression mode 'best' is fine), click 'OK'
Copy the modified 'SunvellWin8Launcher.apk' back over to '/system/app/SunvellWin8Launcher/'
Change permissions of 'SunvellWin8Launcher.apk' to 644 (Using Root Explorer or similar).
Reboot and hopefully the big kodi tile will open SPMC.
There are currently 1919 users online. 1 members and 1918 guests.
