S-Box, S905X, 2/32GB
FW is a big mistake on this Box.., and I cannot find update...
So I put LibreElec on SD card with Rufus https://forum.libreelec.tv/thread-3588.html - and everything is Working (wifi, bluetooth...) - even the remote controler from this Box...
This aplication from GP - Reboot to LibreELEC https://play.google.com/store/apps/d...otupdate&hl=en helps big to boot to LE because there is no way to do "toothpick method"
FW errors from Android
1. HDMI CEC function keep rebooting box when put my TV to program mod and go back to HDMI input
and
2. there is no dark picture in Kodi 16 (LE) - error on S905X chipset...
now in LE not exists...,
Now I am happy - because S-Box is now a powerfull Kodi machine..., but Android with FW update is a big thumb down...
I put Wookie Retro Build on LE (Kodi 16) and it is fast as hell, great.., great buid, heavily loaded - for clear, smooth and above all very fast Kodi experience... ---- with only ONE "problem" - Now I do not have LibreElec shoutdown option to boot back to nand...(boot to Android)... is there any solution to edit shoutdown option in Wookie... !??
It was 10 pieces with this price... I will take photo of other side of PCB..
I opened the Box and there is no informations on the other side.., not any kind of written signs...
I
am also not sure is this Box is 2/32GB, because some like "spec device", - Aida and other aplications, some said that Box has 32GB, some said 16GB, some said 2GB, some 1GB.....
Originally posted by sappy View PostIt was 10 pieces with this price... I will take photo of other side of PCB..
I
I also got it for 19,99 $ on flash sale and the product ia as mentioned in first postBuy best quality of S-BOX Amlogic S905X TV Box KODI Quad Core 64bit Android 6.0 4K HD 3D WiFi Bluetooth 4.0 DLNA HD- 2G+32G EU Plug from Tomtop.com, various discounts are waiting for you.Last edited by tamonegdje; 19 February 2017, 21:31.
For me S-Box with this FW works much better than the original
Dowload link: https://mega.nz/!V98yXJBS!tJ8HnXj1xr...1WZNe8r1MkGXmE
With final test2 version google services crashes.
You need to change the remote.conf file in /system/etc with:
The remote switches off the device with power button and on with #2
Cheers
There are currently 1640 users online. 0 members and 1640 guests.
