HIGOLE GOLE1 Cherry Trail Z8350 Quad-core Windows 10 2.4GHz / 5GHz Dual-band WiFi Bluetooth 4.0
    Intel Cherry Trail T3 Z8350 Quad-core Windows 10 OS 2.4GHz / 5GHz Dual-band WiFi Bluetooth 4.0
    Click image for larger version  Name:	4.jpg Views:	1 Size:	45.9 KB ID:	623317
    Main Features:
    Portable, compact, delicate and exquisite: it has a surprisingly high-end configuration, change the traditional concept of the computer
    The processor in this chip is an Intel Cherry Trail T3 Z8350 Quad-core
    Intel Gen 8-LP as GPU of this TV Box which gives you the high definition pictures and videos
    With Windows 10 OS, we will have high speed feedback and smooth response
    4GB LPDDR3 + 64GB eMMC, 128GB maximum extended capacity. Easily enjoy many games and movies
    Bluetooth V4.0 connectivity: easy pairing with most Bluetooth-enabled devices
    2.4GHz / 5GHz Dual-band WiFi standard: IEEE 802.11a / b / g / n, connecting effortlessly in a world without wires
    Support wire and wireless keyboard and mouse, flash 11, HTML 5, browser, video 1080P output, decoding 4K video
    With a rechargeable 6000mAh lithium-ion battery
    Click image for larger version  Name:	3.jpg Views:	1 Size:	49.8 KB ID:	623316
    Click image for larger version  Name:	2.jpg Views:	1 Size:	57.7 KB ID:	623315
    Click image for larger version  Name:	1.jpg Views:	1 Size:	30.8 KB ID:	623314
    Gearbest
    On the first image on the left hand side there is something that I can't seem to be able to identify and I've eliminated any of the regular ports from the specs.
    Edit: Now I can see that it is a speaker.
      A couple more images.
      Click image for larger version  Name:	Gole1-Plus-back.jpg Views:	1 Size:	30.7 KB ID:	629425
      Click image for larger version  Name:	Gole1-Plus-Mini-PC.jpg Views:	1 Size:	80.9 KB ID:	629426
        This made me chuckle
        How not to create a fake review.
        First tell people about your basic experiences of this brand new product.
        Then list the specs on an older model and details things that are not present on the latest one.
        Then provide a purchase link to the one that you claim to be reviewing.
        Finish with an incorrect conclusion and a score card.
        http://www.ringosoft.com/higole-gole1-plus-review/
          More Info on the GOLE1
          HIGOLE GOLE1 Plus mini PC specifications:
          • CPU – Intel Atom x5-Z8350 “Cherry Trail” quad core processor up to 1.92 GHz
          • GPU – Intel Gen 8-LP
          • OS – Windows 10 Home 64bit (Activated)
          • Memory – 4GB LPDDR3
          • Storage – 64GB eMMC flash (128GB optional) + micro SD slot up to 64GB
          • Display – 8″ capacitive touchscreen display with 1280×800 resolution; 5 points Multi-touch, G+G
          • Video Output – HDMI 1.4 port
          • Audio I/O – HDMI, 3.5mm headphone jack
          • Connectivity – 10/100M Ethernet, Dual Band 802.11 b/g/n Wi-Fi, and Bluetooth 4.0 with internal antenna
          • USB – 2x USB 2.0 host ports, 1x USB 3.0 port
          • Misc – Power, volume and back buttons, Speaker 1W
          • Battery – 6000mAh battery
          • Power Supply – DC5V/3A
          • Dimensions – 198 X 136 X 27mm (aluminum case and button)
          • Weight – 600g
          GOLE1 Plus box
          What we find in the box? The box included everything that you need to get started:
          • HIGOLE GOLE1 Plus mini PC
          • HDMI Cable
          • Power Adapter (EU)
          • 2x Metal Stand Poles
          • English & German User Manual
          GOLE1 Plus
          GOLE1 Plus mini PC and Accesories (Click to Enlarge)
          GOLE1 Plus mini PC is very well made. Aluminum housing with golden highlights the quality and value of the product. At the top of the device you will find glossy touchscreen 8 inches, with the logo of Windows. GOLE1 Plus makes a great impression, it’s really high-quality device. As we wrote in the beginning a mini PC is equipped with Intel Atom x5-Z8350 quad-core, up to 1.92GHz. GOLE1 Plus runs on Windows 10 Home 64bit (not activated) just connect the device to the Internet system will be activated. By mounted screen we have access to easily browse all files stored on the mini PC and the ability to take full advantage of the device for work and entertainment. However, if we want to work “seriously” just hook up GOLE1 Plus via HDMI to a larger monitor, and connect the mouse and the keyboard (great!), but more on that in the review.
          GOLE1 Plus
          GOLE1 Plus
          GOLE1 Plus
          On the right side of the device you will find: headset port, USB 3.0 port, USB 2.0 port, Power LED, Volume – / + buttons, Power ON / OFF button
          On the back we find: DC Input, RJ45 Fast Ethernet port, HDMI 1.4 port, USB 2.0 port, Mirco SD card slot, RESET hole GOLE1 Plus
          On the left side: Speaker hole
          At the bottom of the device there are rubber pads to prevent shifting, also has holes for the discharge of hot air, and sound coming out. s you can see there are also holes for wall mounting via VESA standard (MIS-D 75x75mm) and sloped position on desktop like as below, screw up both metal poles into mounting hole.
          GOLE1 Plus
          GOLE1 Plus
          GOLE1 Plus
          GOLE1 Plus
          GOLE1 Plus
          Below is a GOLE1 Plus picture in combination with the Samsung 10.1″ tablet to make it easier to imagine the size of the device. GOLE1 Plus
          GOLE1 Plus
          GOLE1 Plus
          Source: AndroidTVBOX
            Thanks to Gearbest and DHL today we can have a look at the HiGole Gole 1 Plus
            Mini PC, Windows 10 ,Intel Atom X5-Z8350 ,Quad Core, Intel Gen 8-LP, 4G /128GB, Dual Wifi, Fast Lan
            Test so far good, Windows 10 responsive and all updated to the Latest yesterday to the latest Versions.
            WiFi Ok as Ethernet, Touch screen good or either using Ext Keyboard and Mouse.(720p) 1280 x 800 very readable.
            Output of HDMI looks good on TV in 1080p.
            Some may say little Bulky to handle but the 2 steel posts make it easy to stand on desk if required both in Landscape and Portrait.
            A quick look on the inside plenty of space to add bits if you think its needed.
            Audio from small speaker is well fair with all that room they could have beefed it up a little more I feel.
            There is the headphone sockets and they sound fine with Phones plugged in or external speakers if you like.
            Easy to add an external antenna as you can see on PCB socket connection if running portable not required may bet in the way
            Gearbest
              System Information and testing on the
              HIGOLE GOLE1 Pro Cherry Trail Z8350 Quad-core Windows 10 2.4GHz / 5GHz Dual-band WiFi Bluetooth 4.0
              Windows can be fully activated so all good
              Basic Info Hdd
              Device manager
              CPU ID
              Stress test for 16 minutes, Peaked
              Antutu Ok for the capabilities for this Unit
                Using with BT mini keyboard
                Not a bad little at all, does as expected for Ram and CPU ideal small office, easy to connect to larger screen 1080 full screen.
                  Wow! There is a lot of space in the case.
                  Nice review.
                    Very roomy indeed fill it up with more batteries I say.
                      Mine caught fire after consistently only staying up for a maximum of 10 minutes at a time.
                      Don't know exactly what the cause was but I suspect the lithium battery will have been the likely candidate.
                        That doesn't sound good!!
                          It didn't do my white ceiling any good either.
                            Hope we have some Photos...Sounds like a good post about safety and Dangers...of media boxes.
                              I heard of Halt and Catch Fire, did it halt first?
                              Seriously though, lucky you were near, so domicile not go with box.
