Dolamee D6 TV Box 2/8gb 2.4G WiFi Fast Lan. BT4
Tags: None
Today we start to have a look at the Dolamee D6
Amlogic 905x 2/8gb Android 6, 2.4Ghz WiFi, Fast lan BT4.
GearbestLast edited by trebor; 26 January 2017, 04:22.
Look At the Insides of the Dolamee D6
Nothing much underneath to see
Top Side Plate on Lid actually used for a little cooling as well
Front display Power and IR Pickup
WiFi Chip
Ram Spectec and Smasung eMMC
WiFi Antenna and weights plate/Secondary Heat Sink
Ports
and More Ports
Gearbest
Hmmm ddr4 wasnt expecting that extra port hook up for fan or serial very nice. No quick connect wifi ...
Wifi different then normal. Cant wait to see how it preforms hopefully a surprise like the d5
And yes a CLOCK.... Costly vents tooo wow... And a big chunck of metal kinda becoming standard. (They may one day understand better heat sink setting and part cheaper then the big hunk of metal.)
Look at Performance, Information and other Benchmarks of the Dolamee D6
Runs a little warm up to 90c using apps.
Weather App appears to to work at the present.
Groovy looking Launcher, Hate it alreadyscroll around drives me nuts.
Got this crazy thing to uninstall apps, can got the other way thru settings etc
This Crazy thing to Move/Remove Apps from Home or Favorite
9 day old or so Rom
Feature to Fiddle with
Full Display
DRM Level 3 only
Version Installed....not for long
CPUZ Info
Storage Truth
Ram Truth
Antutu ok for a 905x
Very Ordinary A1 memory Test if its ddr4
http://browser.geekbench.com/v4/cpu/1697714, Low Score
More Ordinary scores here: http://browser.geekbench.com/v4/compute/403459
Bit more fiddling this day, Youtube and Netflix stream ok no drop outs using 2.4ghz.
Does get a bit warm the D6 in the 100c area at peaks 90c average, think it has to do with the launcher,
The Weather widget came good today, Launcher is OK but you need to Left or Right a lot to find apps.
Top Right Corner of main Launcher, Icons for Weather (Set area), Appearance (Change background) and Settings all can be clicked and used
Not to bad for a streamer and the Basics
First release of rom so maybe there will be some improvements further down the track
Unit does have Root.
Just got one of these so a couple of quick questions for Trebor.
Found out how to remove items from the home screen but how do you add them? Installed kodi 17.3 and can't get it into the scroll menu. Also - uninstalled TVMC but that tab seems hard coded into the desktop and the normal options key doesn't pull up the four way "re-order/remove" menu shown in your pics.
Lastly tried to install a few alternative launchers to get rid of this POS. There are two system apps "Amazing Launcher" and "Launcher". neither of which seems to want to disable or uninstall.
Any pointers would be much appreciated. Seems like a decent low cost TV Box apart from the damn launcher so hoping I can get that sorted quickly
Originally posted by trebor View PostD5
There are currently 1875 users online. 0 members and 1875 guests.
