Hi, this is my first post. I just found out about this website and since i couldn't find anyone with my problem i will ask you for any help. I have a sunvell t95m with 2gb of ram and a s905x processor, purchased last christmas from gearbest.
When i try to shutdown, the box turns on by itself (shows "boot" at the led screen) and it's running again. I already made a factory reset, any tips?
I can only suspend the tv box, i wanted to do a shutdown because i will cut the power after i use the device.
