MK809IV RK3229. Bricked. How to unbrick??
** I actually got notification to my outlook email **
Have you tried flashing?The Case for Reform
Drug Science Prof D. Nutt
The life of a good person means more to me than that of a bad person.
I have no borders as far as good people go.
Thanks for your reply. I have tried all firmware from
http://chinagadgetsreviews.com/firmw...-tv-stick.html
http://chinagadgetsreviews.com/firmw...v-stick-2.html
http://chinagadgetsreviews.com/downl...-tv-stick.html
And few others - none work for me...
Every time to flash a new image, I need to short pins on NAND - this allows the RK tool to recognize device and flash. But despite successful flash the stick will not boot....
I don't have a decent camera, but this is the PCB:
nitially I tried to solder wifi antenna, but that neither improved nor worsen the wifi... (I am not even sure if those are solder pads for antenna to be honest)
At this point I will take ANY version that boots, or maybe I am doing something wrong? I just flash the image with RKBatchtool 1.8 - wait for it to go green and then disconnect and reboot.
CPU: RK3229 SDDKN070061
WIFI: RTL8703AS
NAND: SK HYNIX H27UCG8T2ETRYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Hi gupii ,
first please let the Device a little bit longer connected to Pc after flashing maybe 4 to 5 minutes ,
so it can do his work first .
second , do you have a unified storage or splitted ??? , ever tried AndroidTool 2.35 with "erase Flash"
Function for flashing ???
third , do you have a stock Firmware and does it boot ???
maybe you have to use differnt parts from 2 Roms .
please answer
nice Day
gefattern
Thanks gefattern,
I have waited up to 20min, no luck.
I have not tried AndroidTool, will try that. I don't have the stock firmware, because as dumb as I am - I did not think to copy it first, before I flashed a different one....
Many thanks for trying to help - I will try the Android tool and let you know.
Regards,
gupii
Hi gupii ,
please try Mo's Firmware once , if it boots ??? and report .
What Version was the stock Firmware ??? KK or LP or MM ,
ever ask the Company where you buy it ??? , for a FW link . Ask .
Only one 2/16GB RK3229 Device on Market ??? , please try and
report .
good luck
gefattern
Edit : i ask a Seller of this Devices on Ali for a FW maybe it helps , pressing thumbs .Last edited by gefattern; 04-27-2017, 12:31.
Hi gefattern,
Tried flashing with Anadoridtool 2.35:
12:59:18 896 Android开发工具 v2.3.5.2 start run
12:59:28 415 Error:CheckDownloadItem-->..\rockdev\Image\misc.img is not existed!
12:59:30 501 Layer<>: RunProc is ending, ret=0
13:00:00 882 AndroidTool v2.3.5.2 start run
13:01:02 261 AndroidTool v2.3.5.2 start run
13:29:17 855 Layer<2-1-1-3>ownload Boot Start
13:29:20 226 Layer<2-1-1-3>ownload Boot Success
13:29:20 244 Layer<2-1-1-3>:Wait For Maskrom Start
13:29:20 826 Layer<2-1-1-3>:Wait For Maskrom Success
13:29:20 837 Layer<2-1-1-3>:Test Device Start
13:29:20 856 Layer<2-1-1-3>:Test Device Success
13:29:20 878 Layer<2-1-1-3>:Get FlashInfo Start
13:29:20 887 <LAYER 2-1-1-3> INFO:FlashInfo: 00 00 09 01 00 20 20 28 20 02 01
13:29:20 930 Layer<2-1-1-3>:Get FlashInfo Success
13:29:20 947 Layer<2-1-1-3>:Prepare IDB Start
13:29:20 989 <LAYER 2-1-1-3> INFO:CS(1) (8480MB) (HYNIX)
13:29:21 017 Layer<2-1-1-3>:Prepare IDB Success
13:29:21 037 Layer<2-1-1-3>:Erase IDB Start
13:29:21 121 Layer<2-1-1-3>:Erase IDB Success
13:29:21 250 Layer<2-1-1-3>:Reset Device Start
13:29:22 275 Layer<2-1-1-3>:Reset Device Success
13:29:22 298 Layer<2-1-1-3>:Wait For Maskrom Start
13:29:22 887 Layer<2-1-1-3>:Wait For Maskrom Success
13:29:22 901 Layer<2-1-1-3>ownload Boot Start
13:29:25 231 Layer<2-1-1-3>ownload Boot Success
13:29:25 250 Layer<2-1-1-3>:Wait For Maskrom Start
13:29:25 748 Layer<2-1-1-3>:Wait For Maskrom Success
13:29:25 762 Layer<2-1-1-3>:Test Device Start
13:29:25 776 Layer<2-1-1-3>:Test Device Success
13:29:25 789 Layer<2-1-1-3>:Get FlashInfo Start
13:29:25 857 <LAYER 2-1-1-3> INFO:FlashInfo: 00 00 09 01 00 20 20 28 20 02 01
13:29:25 869 Layer<2-1-1-3>:Get FlashInfo Success
13:29:25 880 Layer<2-1-1-3>:Erase Flash Start
13:29:26 188 Layer<2-1-1-3>:Erase Flash Success
13:29:26 263 Layer<2-1-1-3>:Reset Device Start
13:29:27 297 Layer<2-1-1-3>:Reset Device Success
13:29:39 720 Layer<2-1-1-3>ownload Boot Start
13:29:42 045 Layer<2-1-1-3>ownload Boot Success
13:29:42 063 Layer<2-1-1-3>:Wait For Maskrom Start
13:29:42 649 Layer<2-1-1-3>:Wait For Maskrom Success
13:29:42 682 Layer<2-1-1-3>:Test Device Start
13:29:42 692 Layer<2-1-1-3>:Test Device Success
13:29:42 714 Layer<2-1-1-3>:Check Chip Start
13:29:42 726 Layer<2-1-1-3>: Check Chip Success
13:29:42 737 Layer<2-1-1-3>:Get FlashInfo Start
13:29:42 746 <LAYER 2-1-1-3> INFO:FlashInfo: 00 00 09 01 00 20 20 28 20 02 01
13:29:42 758 Layer<2-1-1-3>:Get FlashInfo Success
13:29:42 768 Layer<2-1-1-3>:Prepare IDB Start
13:29:42 776 <LAYER 2-1-1-3> INFO:CS(1) (8480MB) (HYNIX)
13:29:42 842 Layer<2-1-1-3>:Prepare IDB Success
13:29:42 853 Layer<2-1-1-3>ownload IDB Start
13:29:45 194 Layer<2-1-1-3>ownload IDB Success
13:29:45 214 Layer<2-1-1-3>:Reset Device Start
13:29:46 237 Layer<2-1-1-3>:Reset Device Success
13:29:46 254 Layer<2-1-1-3>:Wait For Loader Start
13:29:47 207 Layer<2-1-1-3>:Wait For Loader Success
13:29:47 240 Layer<2-1-1-3>:Test Device Start
13:29:47 285 Layer<2-1-1-3>:Test Device Success
13:29:47 324 Layer<2-1-1-3>ownload Firmware Start
13:29:47 343 <LAYER 2-1-1-3> INFO:Start download image,total=879632140
13:29:47 421 <LAYER 2-1-1-3> INFO:Start to download trust,offset=0x4000,size=4194304
13:29:48 113 <LAYER 2-1-1-3> INFO:Start to download uboot,offset=0x2000,size=4194304
13:29:48 765 <LAYER 2-1-1-3> INFO:Start to download misc,offset=0x8000,size=49152
13:29:48 801 <LAYER 2-1-1-3> INFO:Start to download kernel,offset=0x12000,size=7565364
13:29:49 712 <LAYER 2-1-1-3> INFO:Start to download resource,offset=0xa800,size=5604864
13:29:50 391 <LAYER 2-1-1-3> INFO:Start to download boot,offset=0x1a000,size=1438496
13:29:50 628 <LAYER 2-1-1-3> INFO:Start to download recovery,offset=0x2a000,size=10502144
13:29:52 265 <LAYER 2-1-1-3> INFO:Start to download system,offset=0xa4000,size=846057472
13:32:33 048 Layer<2-1-1-3>ownload Firmware Success
13:32:33 089 Layer<2-1-1-3>:Reset Device Start
13:32:34 115 Layer<2-1-1-3>:Reset Device Success
No boot...
Firmware was from http://chinagadgetsreviews.com/firmw...-tv-stick.html
I did write them for FW link, but no luck - and seller I bought it from on aliexpress is now gone, not selling anything
I don't know how to check if I have any partitions in flash - all ReadFlash etc in AndroidTool fail. I don't know what the stock firmware was exacly, but it was 5.1.1 - not sure about kernel.
Thanks again for your help, do you know how can I check for partitions on NAND?
Hi gupii ,
please try once this Rom :
http://freaktab.com/forum/tv-player-...w-rom-by-mo123
to see if it works .
Do you know if the stock FW had a unified Storage or not ???
and can u still reach the recovery ???
good luck
gefattern
Hey - same case, writes flash without problems, does not boot...
I don't know if it had unified storage, recovery is not working. The device is not booting up at all I think - there is a blue led which informs if device is on. It has to levels of brightens - it lights up slightly when there is power and then gives more light when system is up (or starting). At least this was with stock firmware.
Now it only lights up slightly and stays like that - no boot progress whatsoever....
Lesson learned for me - COPY NAND BEFORE YOU FLASH
I think I have bricked this beyond repair...
Originally posted by GeraStrummer View PostMY DEVICE: Mini Pc Android 5.1 Smart Tv 4k Quadcore 16gb 2gb Ram Tv Box.
mk809IV RK3229
Hi. i flash the firmware, everything went cool.
But when i connect it to the power, the blue lights turns on but lighter than before.
nothing appears on screen. try to enter in recovery (pushing the reset button and plug in the power) but nothing happened.
i was trying to do a downgrade beaceuse my 5.1.1 android version wasnt working well.
any ideas how to revive my device??
its the black dongle with the red antenna. some pics of the inner device
EDITED 21-01
I found the way to flash it, shot the 7 and 8 pin of the nand.
batchtool recongnizes it, but it appears in blue.
im looking now for the firmware. try a few and the stick doesnt work
anyone has the firmware for this crazy litle stick??
I'm with the same problem as you.
Can you please post an image with which pins should we short to flash it?
Hi all.
I'm having a similar problem. Mine is as MK809IV RK3229 RL8703AS 2G/8G.
With roms from chinagadgetsreviews I get stuck in logo. With roms from this forum, not even the logo appears and I have to short the pins go get it recognized by the pc (although with chinagadgetsreviews roms that doesn't happen).
Anyone can figure out what could be the problem?
Hi to gupii and all others ,
The only 2/16GB i found was the plus Version .
I wrote a Mail to a Seller on Ali and ask for a FW , for this Device , hope he
answers and can help .
I dont have this Device , i use UT3/UT4/QBox .
Hint for all , next time buy a little bit better supported Device . Good luck .
gefattern
I tried UT6 roms 1.0.0 and 1.1.1 - 1.1.1 does not flash correclty, 1.0.0 does flash, but doesn't boot. So, still no luck...
Edit:
I found one interesting thing here:
quote:
I opened up a V88 and MX4 to compare. The V88 board is actually labeled MX4N-V02. The MX4 board is marked MX4-V10. The V88 has a different wireless chip, SV6051P. While the MX4 has RTL8703AS.
So it may be possible to use firmware for MX4-V10 - so far I haven't found it...
There are currently 2271 users online. 6 members and 2265 guests.
