New Firmware Egreat A5_20170119_v1.1.0.7.rar Release (2017-01-19 v1.1.0.7)
    Note: Egreat A5 EN firmware includes "Release" version and "Beta" version,
    "Release" version firmware will be updated per month, you can download it click here
    "Beta" version firmware will be updated per week, which is only for some enthusiasts who like to test some new problems and solved problems in advanced.
    Egreat A5 EN Firmware V1.1.0.7 Release
    I. info
    A5BD_EN_Firmware_20170119_v1.1.0.7.rar
    Updating Time: 19th, Jan 2017 Thursday, at 10:50:37 a.m
    MD5: B52667EB64DC8139665A95BCA7B65710
    DownloadLink:
    http://data.egreatworld.com/A5BD_EN/...9_v1.1.0.7.rar
    II. Recovery the firmware instructions
    1.If your current firmware is befoe v1.0.1.5, please force to recovery V1.1.0.7 firmware, user datas will be erased.
    2.If your current firmware is v1.0.1.5 or after v1.0.1.5, you can upgrade the firmware by OTA directly or USB upgrade. And you also can force to recovery V1.1.0.7 firmware, user datas will be erased.
    3. The force to recovery new version firmware instruction, please click here.
    III.Changelog
    01.Add:Built in Googleplay *
    02.Add:3D filp eyes function *
    03.Add:Titles and trailer can be seek at blu-ray menu playback *
    04.Add:Embedded subtitles can adjust the display position *
    05.Add:Supported 23.976Hz playback in local player *
    06.Add:Added custom external subtitle default size, color, position setting *
    07.Add:Subtitle and Audio switchover instantly *
    08.Add:Support DVD .ISO movie playback *
    09.Add:Support VCD .DAT movie playback *
    10.Add:Support .TP movie playback
    11.Add:Adding LED display panel setting (display playback time/remaining time/clock/ turn off when playing) *
    12.Add:Support the newly added keys of new version remote *
    13.Add:Auto audio passthrough function
    14.Add:SMB/NFS network auto search function
    15.Add:A new onekey subtitle audio switching function
    16.Add:A new smart time seek playback function
    17.Add:Added volume setting is prohibited in passthrough mode tips *
    18.Add:Vidon xbmc pro supported BD Menu/Passthrough/3DISO movie playback
    19.Add:Vidon xbmc pro supported 23.976Hz playback*
    20.Add:Vidon xbmc pro supported onekey subtitle audio switching function *
    21.Add:Vidon xbmc pro supported page button switching chapter *
    22.Add:Support breakpoint play in filelist mode
    23.Add:Support some non-standard dts audio
    24.Add:Add reminder “press up to safety remove the hard disk and USB storage devices.” in devices list
    25.Add:Movie details showed on the filelist
    26.Add:Added "Show details in file playback" option in "Settings-Playback"
    27.Add:Added "Blu-ray" category in poster wall
    28.Add:Support Farsi subtitle
    29.Add:Error log report function
    30.Optimize:No stutter when switching Subtitle Audio *
    31.Optimize:Improve auto network share search time *
    32.Optimize:The poster can’t visit the readonly network sharing folder, there will be a tip "This position requires read and write permissions" *
    33.Optimize:NFS network sharing folders containing spaces can be added manually *
    34.Optimize:Added more information in "Setting-about" *
    35.Optimize:Improved response speed when entering and exiting folders
    36.Optimize:Clear poster data at any time
    37.Optimize:The page button can flip in circular wall poster and file list
    38.Optimize:Screen optimization when movie pause
    39.Optimize:Information interface real-time update
    40.Optimize:Improve the compatibility for 4K moives
    41.Optimize:Added BD/3D/4K/3D BD tag on poster wall
    42.Optimize:External subtitle setting function
    43.Optimize:Show last breakpoint time when resuming
    44.Optimize:Added "year information" on editting movie blank poster wall
    45.Change:Move "3D mode" from "Setting-display" to "Setting-playback"*
    46.Change:Unify UI design*
    47.Change:Turn on the machine default to standby
    48.Change:Cancel the "other chapters" playback options in poster wall
    49.Change: Playback exit confirmation default to YES
    50.Change:The load devices no working under power on standby mode
    51.Change:Some UI design and operation tips
    52.Change:Initial search mode on poster wall
    53.Change:Optimize the volume bar
    54.Change: Do not change color space when playback
    55.Change: Deleted "playback will be ended soon" tip
    56.Change:Online subtitles temporarily cancelled (Will be recovery soon)
    57.Fix:At 4K resolution play 3D movie will lead to black screen or screen blurred
    58.Fix:The picture may regress when switching subtitles or audio
    59.Fix:TV series details page does not show posters and ratings
    60.Fix:Add external subtitles from Subtitle folder when playback under poster wall
    61.Fix:Audio and subtitle list full languages when system language is Chinese
    62.Fix:some 4K .TS movies cannot play at 4K resolution
    63.Fix:Solve the 3D play 3DISO has in the BD menu cannot play main movie
    64.Fix:The movie may can not playback in the poster
    65.Fix:The movie may play an error in the poster
    66.Fix:Some blu-ray movies can't resume from breakpoint
    67.Fix:3D movie may be screen blurred when playing BD menu
    68.Fix: Drag the progress bar may disappear when playing
    69.Fix:Custom font will affect the issue of SRT subtitles font
    70.Fix:Some of Add-ons on Vidon xbmc pro can't work
    71.Fix:Some Blu ray menu translucent text display is not clear
    72.Fix:Sometimes TV series can’t enter in poster*
    73.Fix:Sometimes can’t visit movie poster issue *
    74.Fix:Can't turn on Egreat Media Player connecting some TV *
    75.Fix:No standby mode in few devices *
    P.S Lists with * are differences from V1.0.2.1 Beta Firmware, lists without * are differences from V1.0.1.5 Release Firemware.
