Use the Usb burning tool to write the image
[ROM][BETA] Custom Mod Rom for MXQ Pro 4K based on XannyTech Custom Mod Rom
Originally posted by Toetje583 View Post
I diden't test Kodi 16, did you mean playing a videofile? This is mosly a videocodec issue.
If you have any more questions let me know!
Best Regards,
Toetje
I have only one issue, not able to turn on the device with my remote, i already copied the original Nexbox Remote.config file, everything works after booting up, any help will be greatly appreciated.
Using Nexbox A95x, 2GB/8GB
Originally posted by ssarava9 View Post
This is great ROM and installed it everything works fast and smooth, thanks a lot for the great effort.
Glad you like it
Thanks for your help, another issue i find is that my internal storage only shows 4.2 GB but i have 8GB, is this a known bug ?
Please help
df
This wil list all partitions etc, you can forward it to me in a private message.
Originally posted by yaro8558 View PostHello,
I've got a problem with my wifi. It loss connection every 10-30 minutes. I bought usb wifi card and i tried to use it but it has realtek 8192SU chipset and there is no module for this card.
Can You add that module to your software ?
thanks
Just realized that I was not subscribed to this thread as I thought , like wise I have missed a ton of information. Since getting a S92 for a primary box and have it the way I want it short of finding the right ftmc build.
I have been considering taking my chances trying to flash my MXQ with a bootable SD, since my computer doesn't seem to detect any of the 3 Aml boxes I have tried.
I haven't found any more info on how the ReMan chip might affect things.
if anyone else with this box finds that the manufacturer of their nand chip is scored out (with Two lines of the letters RM repeated) let me know.
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 3345 users online. 0 members and 3345 guests.
