T96 pro
T96 pro
I have tried a search, apologies if I have not done so properly. I recently purchased a T96 Pro (s912 3gb/16gb). It looks very similar to the R-Box/ H96 Pro. The only visible difference being that it only has 2 usb ports. The firmware is terrible! I have had no luck trying to find an Update. I have Flashed the H96 Pro firmware update using the Amlogic USB burning tool, While it has made improvements in some areas. It (as could be expected) caused additional problems. Can anyone advise me on a suitable firmware please? Or have I just made a bad purchase? Thank you for any tips! -
Hi rowfeetv,
I have also bought this model and i must say that i am quite satisfied with this product.The reason i bought this model was that it said that it supported BT4.1 (but i did not verified it yet).
I think the H96 Pro comes from the same factory.As the T96 PRO is also sold under the Unuiga brand.
http://www.vissontech.com/products_d...ductId=82.html
(got the link from a post from calc in rom section)
Yet i am still waiting for the guys at freaktab to make a custom rom for it (currently i have no problems with it so not in a hurry to flash my device).
Originally posted by ghostdog View Posthttps://drive.google.com/file/d/0B8j...w?usp=drivesdk
Hi , the link above is for the latest firmware xxxx010 available , its perfectly working , i flashed it into my bricked T95R pro , using Usb flash tool . it works perfectly.
Originally posted by ghostdog View PostI am really sorry for that , The firmware is been supplied to me by the manufacturer , it is for any device that is Amlogic S912 , it worked perfectly on mine, i dont know the specs of your device, i gave you the firmware in good faith.
T 96 pro OTA UPDATE https://www.dropbox.com/sh/4bxjuderl...96_sdcard?dl=0
rename t96-ota-20161212.zip to "t96-ota-root.zip"Last edited by tushar007; 03 February 2017, 10:29.
Originally posted by rowfeetv View PostI have tried a search, apologies if I have not done so properly. I recently purchased a T96 Pro (s912 3gb/16gb). It looks very similar to the R-Box/ H96 Pro. The only visible difference being that it only has 2 usb ports. The firmware is terrible! I have had no luck trying to find an Update. I have Flashed the H96 Pro firmware update using the Amlogic USB burning tool, While it has made improvements in some areas. It (as could be expected) caused additional problems. Can anyone advise me on a suitable firmware please? Or have I just made a bad purchase? Thank you for any tips!
try this mathed dead board only or no't booting t96 board only (do not try other board or other company TV box)
*do not connected box adapter 5V/2A (OTG USB cable cantered your box only)
*connected your laptop power supply ac adapter source
*opened windows device manager ( left click computer icon mange and click device manager )
fond new comport hardware detectedLast edited by tushar007; 25 February 2017, 20:09.
There are currently 1808 users online. 0 members and 1808 guests.
