Any good soul, could I get a backup of the H96 pro 2gb?????
    I would like to test a way I thought of here to do unbrick from the box.
    If anyone can do me this favor, I would be grateful.
    Just download the recovery.img from the link, put in a sd card in fat32 formated. Put in box and then turn on the box. Recovery mode will already start in twrp.
    I need a twrp backup to test the unbrick. Please help me!
    Works to in Rbox pro, h96 pro, and amlogics s912 boxes, with board q6330, 2g 16gb
    If possible, you can do this, see if it appears in 0mb, all mounted memory. internal, and sd card. Thankssss!!!
    Link recovery.img: http://www.mediafire.com/file/z8wep1...i/recovery.img
    try one of the s912 roms from the rom/firmware forums. One of them should able to work with your box.
      Firmware of this device is here
        Originally posted by theguyuk View Post
        Thanks for the help friend, but I needed the backup, as it would use as a last resort, since already tried to burn this firmware by usb burning tool and usb burn card maker and always the error in loading.
