i would like to ask you guys about a problem with my tablet.
It worked just fine after purchasing for 4-5 months. After it happened something, i don't know what could cause it, but i didn't drop it nor tried to take it apart. So actually i tried to take care of it as much as possible. I also didn't modify its system. (rom/firmware, it has still the stock rom).
The problem is: the touch screen's left 1cm stripe/streak from the quite top to the bottom like a very straight line couldn't detect my finger's touch. (i mean not just mine, usually
And also the windows sign (which is a touch button under the screen doesn't work either)
If i'm rotating the device, or flip it, the not working stripe/streak remains on the same side(physically ofc).
I tried to diagnose the problem, so i turned on 'developer options' and to 'show touches'. It confirmed what i have already noticed and mentioned above written.
So my question is: is that a defected tablet and has a physical problem with the screen itself or can that be a software problem and can somehow solve the problem?
Since it's a dual boot tablet, i have also tried if the problem remains in windows 10 also, but unfortunately i had to determine that it is also a problem in Windows.
Anyways the screen itself as a display works perfect, no visual problem. If i use it with a mouse there's no problem, but it would be nice if i could use it fully with my fingers too.
Thanks in advance any information, help and your answers.
Matt
PS: Sorry for my english, it's not perfect i'm sure, if something is not sure for you just ask, and i will try to explain somehow else.
