Also the RK Tool detects the hardware and displays "Found RKAndroid rock usb". But I am not able to erase / flash the rom, on clicking I am getting "MSC can't do erase NAND" and "MSC device can't do upgrade" error messages respectively. Please help, I am not able to proceed.
MK808B Flashing issue
I have a new MK808B and I tried to flash the Finless 1.7 rom. I am able to install the drivers, its getting detected as "rockchip_usb" under "Disk Drives" (correct me if it is wrong) in both Windows XP and 7. Device Manager.
Also the RK Tool detects the hardware and displays "Found RKAndroid rock usb". But I am not able to erase / flash the rom, on clicking I am getting "MSC can't do erase NAND" and "MSC device can't do upgrade" error messages respectively. Please help, I am not able to proceed.Tags: None
Any workaround?
Any workaround for the above issue?
Also I am facing the following issues:
- I have CWM Recovery installed, Is there any way to remove it completely?
- A general query, in the Settings > About Device > Build Number, shows the MK808B as the prefix irrespective of removing the values in build.prop file. How to remove that?
There are currently 2047 users online. 1 members and 2046 guests.
