M8s android.
    M8s android.
    Cannot unbrick my M8S Android 4.4.2 APIlevel19 Kernel Linux 3.10.33 tried lots of img recovery file one loaded to 2% any one know how to acheive this?
    Few times delete and reorder. On your computer have as possible not active other programs.If it is possible to reorder Libreelec. It works much better.
      So you have an M8S i guess it is one with S812 CPU is this correct ?
      If yes there are a lot of Image to try let me see what i found the last Time when i unbrick an M8S.
      Neomode
        I have tried lots of img files from China gadgets with no success it did get to 2% with Hugsun_s905X_rt8189s982c_20161123(M... but then nothing I have tried the company I bought it from but it was over a year ago and no come back any help would be good thankyou.
          You're writing that unbrick M8S. M8S has the processor S812. M8s mini has a processor S905x. I wrote you, how to do on M8s and not M8Smini.
            Sorry I just tried the s905 out of desperation nothing will boot this cpu arm7 pr7cu71 it is a Android4.4.2 APIlevel 19 Kernel _linux 3.10.33
              Try this Firmware it should fit your Device.
              FileFactory is the best place to upload and share files with no limits since 2005. Send and receive any type of file up to a massive 5GB with unlimited file bandwidth.
              Neomode
                Thank you I will do and let you know how I get on .
                  This is how far I have got nothing will work every time I import a IMG file it says Parse image failed?
                    Try the following:
                    Plug in the USB Cable
                    Plug in the Power Cable
                    Flash it
                    Neomode
