Of course, it wasn't what I expected.
The box came with a non-US plug (not helpful) and also had a more simplified remote than pictured. I've started a dispute and AmEx will take care of me at the end of the day if necessary.
Questions:
If I dig up a 5V 2A barrel charger and get it to power on, the box has the expected USB connectors, but has BOTH a full size SD card slot and a TF (microSD) slot. Can I put a new ROM/software on the full size SD card, or only in the TF slot?
Do I need root in order to get an alternate, SD card version, of the software to boot?
Is there any way through software to check which wifi chip is in the box? The screws holding the box together (under the rubber ring) may be stripped/driven in too tightly to easily extract.
Thanks all.
Andrew
