Official information about Ugoos Brand TV Box based with brand new RK3399 chipset
New RockChip3399 gives incredible abilities for mobile platforms and mini PC devices.
Rockchip has unveiled the RK3399 processor back at CES 2016 and this SoC now becomes a heart for new Chromebooks performed by ASUS.
As you can see from the specs this is our first Branded TV Box with SATA port and HDD holder. Device will able to connect 2.5 and 3.5 inch hard drives.
Here is a render of a future housing case for Ugoos UT5
Specs:
Operation System: Android 6.0
Languages: English...Multi-Language support
Chipset: RK3399 28nm Dual Core Cortex-A72 + Quad Core Cortex-A53
GPU: Mali860 MP4 OpenGL ES1.1/2.0/3.0/3.1, OpenVG1.1, OpenCL, DX11
Supports AFBC
SDRAM: DDRIII-2133 4G
Nand Flash: 32GB Nand Flash (optional: 16/32/64GB)
Storage Extension: Support SATA, 2.5 Inch or 3.5 Inch, Max 8TB
MicroSD (TF) card, Max to 256GB
Network: AP6359S, 2.4GHz*2/5GHz*2 Wi-Fi 802.11 a/b/g/n and 802.11 AC.
Support LAN 10M/100M/1000M Base-T
Bluetooth: Support BT 4.2 Module
Power Supply: DC 12V/3A
Interfaces:
HDMI
1 x HDMI (A type Female), HDMI2.0, Support 4Kx2K decode output 60fps
USB Ports
USB3.0 x 1 Type-A x 1 USB2.0 x 2
Type-C Support appointed VR sets
Fiber-optical Output 1 x SPDIF
Card Reader 1 x TF
SATA 1 x SATA
Network port 1 x RJ45
Power Supply 1 x DC Jack
Antenna Wi-Fi external 5 dB antenna *3
Media Parameters:
Video Decoder H.265 4096*2304 60fps
H.264 4096*2304 60fps
VP9 4096*2304 60fps
MPG4 1920*1080 60fps
Full video format decoding support:
Formats MPEG-1, MPEG-2, MPEG-4, H.263, H.264, AVS, VC-1, RV, VP6/VP8, Sorenson Spark, MVC
Video Encoder H.264, MOV, 3GP
Video Output HDMI output: Support 4Kx2K (4096x2304) @60HZ HDR
H.265 Data Rate
Up to 60fps.
Software Extension Support Play market & APK install.
Protocols: Support DLNA, Miracast Protocol, Support DRM requirement, airplay, Audio push.
Certificates: CE, RoHs.
As you can see, we built small OLED screen in order to display status messages and some additional information. USB type-C port we placed on front panel for more convenience.
Test results of UT5 PCBA with Ugoos firmware will be a little bit later, now you can check unnamed boards’ tests on Geekbench
Some research information about SoC you can find on cnx-software.com
Ugoos UT5 will be presented on CES 2017 in Las Vegas next January. Everybody will be able to test device and left quote for pre-order. Pre-order is also available on Ugoos website.
Source Freaktab
