Followed all the youtube guides without any luck, have I purchased the wrong remote?
New remote unsuccessful so far in pairing, wrong remote? - Solved steocullen91
Owner of the mini m8s (S905) and dropped the original remote too many times, have purchased the attached remote and unsuccessful so far in pairing it.
Followed all the youtube guides without any luck, have I purchased the wrong remote?Tags: None
I think the problem is that the remonte.cfg file is not the same for your new remote.
Means you have to remap all the Keys.
Did you try to check if the new IR Remote General Work?
You can do this with the Camera of your Smartphone and pointing the ir remote to it then you see the, Ir led working.
Neomode
Originally posted by neomode View PostI think the problem is that the remonte.cfg file is not the same for your new remote.
Neomode
Will have a google around on remonte.cfg files, although sounds tricky.
What can I use to get kodi to boot on startup, from here I can control it by browser
Originally posted by casa View Post
thanks for the quick reponse, check the IR and yes its glowing on my camera.
That should do it. Same remote as my x96."HANDS ARE NATURES FORKS" -Rigby
There are currently 2343 users online. 0 members and 2343 guests.
