I googled for "Tanix TX5 firmware" and selected the 2GB/8GB version I thought best fitted my box. Booted in to TWRP and did the necessary wipe but it reported that the firmware was incorrect and that my box was the "Nexbox A95X".
So I started googling around for the appropriate firmware for that and I found one. It actually flashed and booted ok, but the remote didn't work. So, in my infinite wisdom, i decided to keep looking for firmware where the remote would work rather than actually trying to find a direct solution to the remote issue as i could well have maybe found the correct file to copy across.
My fatal mistake came when I tried to flash a firmware on to the wrong partition in TWRP and assumed i had to free up some space, so did some of the more 'advanced' wipes and essentially formatted the box from inside TWRP. I was aware of this, and the consequences, but took care to make sure i still remained inside TWRP .. until we had a power cut.
Now, my box boots to a "Nexbox A95X" logo and just stops dead.
I've tried the USB Burning Tool with over half a dozen firmwares and it always gets to 5 seconds and errors with ""[0x00101004]Erase Bootloader/Lowper/Identify/Error result""
I've tried it on every USB port on my desktop and had the same error each time. I connect it via the OTG port on the box and still get "Connect Success" each time, but nothing flashes. I've tried about five versions of the USB Burning Tool as well.
I've tried to make a bootable SD card with various firmwares as well and nothing boots.
I don't think i've bricked it because it powers on to the boot logo and i don't think i've wiped TWRP either but I'm just lost. I can't see a way around this to recover it - I can't remember the firmware i found earlier that worked, but even if i did, i don't have a method of getting it on to the box.
I appreciate this might be a bit long and might not make a lot of sense but if anyone has any bright ideas, i'd be very grateful. Thankyou.
