Dead MK902II
Dead MK902II
Hi. I would really appreciate your help. I just bought the MK902II. When I connected it to tv it went into the boot and kept going for more than 1/2 hr. So I tried to restore it, but I got as far as the message "Test Device Success" and got stack on it overnight. I tried newest version (20160722) as well as the older one (2015), both display the same problem. Any ideas? Sorry I posted that in the Main Forum and probably should be here.Tags: None
Originally posted by jbag56 View PostHi. I would really appreciate your help. I just bought the MK902II. When I connected it to tv it went into the boot and kept going for more than 1/2 hr. So I tried to restore it, but I got as far as the message "Test Device Success" and got stack on it overnight. I tried newest version (20160722) as well as the older one (2015), both display the same problem. Any ideas? Sorry I posted that in the Main Forum and probably should be here.
Do a 'EraseFlash' then try to do an 'Upgrade' again.
You hold in a paperclip in the recovery hole when you connect the USB and power cable to it.
It should say 'RK Loader found'
You might also need to install the drivers with DriverAssistant 4.4.
Is AndroidTool v2.35 only for RK3368 or I can use it on RK3288? I tried to go for "Test Device" and the message that I got was "Test device failed". What is it going to do if I go for the "Reset Device". I do have "MK902II_5.1_RKM_ota_20160722.img" image which hopefully I could install (How??) but does this image includes formatting, boot, operating system etc.?? Thanks again for help.
Originally posted by jbag56 View PostIs AndroidTool v2.35 only for RK3368 or I can use it on RK3288? I tried to go for "Test Device" and the message that I got was "Test device failed". What is it going to do if I go for the "Reset Device". I do have "MK902II_5.1_RKM_ota_20160722.img" image which hopefully I could install (How??) but does this image includes formatting, boot, operating system etc.?? Thanks again for help.
Make sure the update.img is over 400MB.
Leave test and reset device out, not sure why you want to use that.
That is a log file error "22:32:05 543 Rockchip Batch Tool v1.7.1.1 start run
22:32:47 792 **********Upgrade Start Total<1>**********
22:32:47 796 <Layer 2-1-2> Download Boot Start
22:32:50 385 <Layer 2-1-2> Download Boot Success
22:32:50 397 <Layer 2-1-2> Wait For Maskrom Start
22:32:50 890 <Layer 2-1-2> Wait For Maskrom Success
22:32:50 901 <Layer 2-1-2> Test Device Start
22:34:41 858 Error:RKU_Open-->CreateFile failed,err=2,path=\\?\USB#VID_2207&PID_320A#6&29CF 3A8F&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
22:34:41 867 <LAYER 2-1-2> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-1),path=\\?\USB#VID_2207&PID_320A#6&29CF3A8F&0&2#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
22:34:42 884 Error:RKU_Write-->WriteFile failed,bRet=0,err=31,size=31,write=0
22:34:43 109 Error:RKU_ClearBuffer-->ReadFile failed,bRet=0,err=31,size=512,read=0
22:34:43 118 <LAYER 2-1-2> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-3),path=\\?\USB#VID_2207&PID_320A#6&29CF3A8F&0&2#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
22:34:44 185 Error:RKU_Write-->WriteFile failed,bRet=0,err=995,size=31,write=0
22:34:44 400 Error:RKU_Open-->CreateFile failed,err=2,path=\\?\USB#VID_2207&PID_320A#6&29CF 3A8F&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
22:34:44 409 <LAYER 2-1-2> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-3),path=\\?\USB#VID_2207&PID_320A#6&29CF3A8F&0&2#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
22:34:45 425 <Layer 2-1-2> Test Device Fail
22:34:45 435 **********Upgrade Done Success<0> Fail<1> Time<117641>ms**********"
I am running windows 10 on my pc Could that be the reason? I am running the program as administrator.
There are currently 2070 users online. 0 members and 2070 guests.
