[ROM] Beelink GT1 / Alfawise S92 Stock & Nano Nexus ROMs (Android 6.0)
Guest
Guest
Ah, yes. That makes sense because the remote control IR code for power up is hardcoded in the bootloader. Your remote's number 2 button emits the same as the power button on my boxes.
Originally posted by vostro View PostGT1 111M0 is out:http://www.bee-link.com/forum.php?mo...=1407&pid=7026
Is there a brightness fix for this firmware?
I know that I can play a 4k video, but I must do that every reboot...
I search for an apk to run on boot... or a config to edit ... or something to do automatically at boot
P.S.
I found a solution:
modify build.prop
service.bootvideo = 0 -> 1
It seams to work ... also with this firmware
I change the boot animation so now I have a great bootvideo and a fix for brightness issue
Originally posted by colm1983 View PostThis is an excellent rom! I was never a fan of the leanback launcher until now, you have done a really good jobs on this, the playstore is limited but I use pureapk to get around alot of the issues. I have flashed it to a rupa A9 Diamond with no problems, I then used the AP6255 UPDATE in TWRP rebooted then went through the setup fine. I justed wanted to ask about the kernal update from superceleron will this work with a different wifi chip ? I have added alot on to the box and dont fancy doing it all again if it bootloops.
I have noticed a few freezes during some games, so I guess that this could be sorted with a change in kernal, I have nofuss cpu installed set at high but it make no real difference.
Thanks again for your great work and I look forward to any updates coming soon
and the fact you flashed this to a Rupa a9. i have one which is used by my family and it has bricked with it now not passing the Rupa flashing logo? i have entered recovery and wipe/data reset makes no difference? any help you can give me would be hugely appreciated, i cannot find any help elsewhere. even if i could put twrp on it would be easier? i cannot get my PC to see it through usb burn tool but am unsure which is the correct way to connect it to the PC as all i have at the moment is the lead for the OTG port, the micro usb? thanks again.
Originally posted by stokesypokesy View Post
Hi, my name is Mark and i was just reading your comments on the rom: [ROM] Beelink GT1 / Alfawise S92 Stock & Nano Nexus ROMs
Originally posted by poul50 View Post
just download amlogic sd burn Card maker to a Windows pc, and choose the rom you want to flash when the sd Card are made sucesfully put it in your device and hold the reset buttom until flashing starts
Thanks for your help, do you know of any ROMs that are confirmed as working for the rupa a9? Or can you use any s912 rom?
bu look at this
i have not this device .....you must find a rom with same wifi ,ram,disksize .....most other specs are the same for all s912 devices
bu look at this
http://freaktab.com/forum/tv-player-...172#post636172
There are currently 4503 users online. 0 members and 4503 guests.
