NEXBOX A95X won't connect to internet
    I got the NEXBOX A95X about 6 weeks ago. It was working fine until I moved it to another room in my house. It said it was connected to the wifi, but when I would try to bring up anything like Kodi, Netflix, YouTube etc, it would get a message saying there was no connection. I thought maybe the wifi signal just wasn't strong enough, so I ran an Ethernet cable this week. I'm still getting the same errors.
    i did a factory reset, hoping that would help, but it didn't. I moved it back to the original location where it was working, but it's not working here either. Even on an Ethernet cable.
    Here are the specs from the site where I purchased it.
    Specifications:
    CPU: Amlogic S905X Quad core Cortex A53 2.0GHz 64bit
    Newest Amlogic S905X Quad core A R M Cortex-A53 CPU up to 2GHz
    A R Mv8-A architecture with Neon and Crypto extensions
    8-stage in-order full dual issue pipeline
    Unified system L2 cache
    Advanced TrustZone security system
    Application based traffic optimization using internal QoS-based switching fabrics
    3D Graphics Processing Uni
    Supports multiple video formats 4:2:0, 4:2:2 and 4:4:4 and multiple pixel formats (8/16/24/32 bits graphics layer)
    MJPEG and JPEG unlimited pixel resolution decoding (ISO/IEC-10918)
    Supports JPEG thumbnail, scaling, rotation and transition effects
    Supports *.mkv,*.wmv,*.mpg, *.mpeg, *.dat, *.avi, *.mov, *.iso, *.mp4, *.rm and *.jpg
    Built-in High Definition Multimedia Interface 2.0a transmitter including both controller and PHY with CEC, HDR and HDCP 2.2, 4Kx2K@60 max resolution output
    Supports all standard S D/H D/F H D video output formats: 480i/p, 576i/p, 720p, 1080i/p and 4Kx2K
    Integrated IEEE 802.3 10/100M Ethernet controller with 10/100M PHY interface
    Supports Energy Efficiency Ethernet (EEE) mode
    WiFi/IEEE802.11 & Blue tooth supporting via SDIO/USB/UART/PCM
    GPU: Penta-core Mali-450MP GPU
    RAM: 1G / 2G
    ROM: 8G / 16G
    USB 2.0 * 2
    Card reader: S D/SDHC/MMC cards
    Support the latest HEVC (H.265) decoding
    Support 4K*2K Super HD video
    OS: Android 6.0
    Wifi: IEEE 802.11b/g/n, 2.4G
    Wired/wireless mouse/ keyboard supported
    Highlights:
    Super Mini and Smart
    NEXBOX A95X is a Super-Mini Android TV Box, very small and smart. Both its length and width are only 93mm and the height is just at a amazing 11mm. You can hold it in your palm.
    No.1 Android 6.0 TV Box
    NEXBOX A95X is the first Android 6.0 TV Box model in 2016. Android 6.0 is to improve user experience compared with other versions of TV Boxes. People can install or uninstall software, games and application programs easily.
    H265 and VP9 decoding.
    The S905X chipset inside this smart TV Box is a adveanced version compared with the original S905 chipset. It supports both H.265 and VP9 decoding, which are the absolute mainstream decoding formats in the glole.
    HDR Vivid World
    HDR is quickly making its way to TV, first to set-top boxes with NEXBOX A95X TV Box. Watch videos in detail like never before with select HDR content. Witness scenes and characters come to life in vivid contrast, color, and clarity.
    KodiCenter
    KodiCenter, developed by NEXBOX engineer team, is a place where users can find many useful Kodi add-ons for their TV boxes. Hee, you can find an add-on which can help to maintain your Kodi (update, backup and much ), so you can be laways updated with your HD video fun.
    One-Key to Live and One-Key to Kodi
    The custom remote control for A95X comes with two special features: One-Key to Live and One-Key to Kodi. Just press one-key and you can watch live TV programs. Also. just press one-key and you can come to the Kodi interface.
    Thanks for any advice you can give.
    Jerry
    UPDATE:
    I'm not sure what fixed it, but it's working again. It was unplugged for about 24 hours, while I ran cat5e cables to various areas. After hooking up everything else, I decided to try working on it again. Once I hooked it up, it connected to the Internet just fine.
      I picked up on another thread here why sometimes wifi worked and other times it didnt at all. Worked yesterday wth, right? Someone suggested turning box over, did it and wifi came back. Still nowhere near wired connection speeds. About 4mbps.
        I have the same unit A95X, and same issue, please help!! just like what what jbicb3 did, it worked again after few days unplugged every cord., but the problem came back again. and no luck.
        I even tried the ethernet and it says: NOT CONNECTED!
        somebody please help
