Thanks for your reply tattman65 I downloaded the CustomizationTool_setup_v2.0.3.zip but I'm still unable to extract the contents the program shows a dialoge "Unpack F:/backup_offiziel/recovery.img failed, i tried also the other img but it doesn't work,
Thanks for further help.
You may have recognized that there is no 1F8B0 code for gzip in the images, they have a different technology?
neomode Oh yes I'm really familiar with Linux. I'm almost going to compile a new kernel for my tablet, so this would be awesome to have the source code of the boot, recovery and bootloader image, thanks for further help.
I'll go now to bed, so I'll download your files after + 8 hours, I'll start the files downloading then after I stand up.
I'm from Germany. For me I'll download the tools tomorrow.
My mkbootimg is also a wrong version it shows that the data load adress is 8000x8000 but the file isnßt that bis, I need the mkbootimg tools from amlogic to get the right positions of the header and so on this is probably why I looked the wring way, I was searching for 8000:8000 but nothing, which is really strange, another versions should help, someone can upload amlogic mkimgtools, whit them I should get proper information about what is where and can unpack them.
neomode For what amlogic SoC's do you have their tools? I sent an email to the amlogic.com support and asked them what tool I have to use, or if they can provide me the tool.
heh almost seems counter-productive that mkbootimg is compiled specifically for certain offsets. ultimately adding another arg to the main(argc argv) params for offset would be optimal. i currently dont have the tools but i may start investigating the tools soon as well to decompile the .img files... ultimately the source is open and a toolchain can be found in the termux apt repo if you dont want to wait. i know that isnt much help but might be a thought you over looked.
Is it true that the .img are containing an instructions for the SoC (Prozessor) A9 Cortex? This is the reason why the files aren't only containing the kernel they are containing also instructions for the SoC, true?
Is anyone willing to help me and get the files (delete out with the tools the processor instructions first) then It must be able to get the gz ramdisk and gz kernel from the img which arenßt containing the processor (amlogic SoC processor instructions).
I trie to $ make (clar the $ stand for normal user (non-root)) but It returns alot of errors, can anyone "make" the two aml_uboot.... or the aml_customer... get working under Linux,
Thanks in advance <Im pretty sure that the 4.9 MB file will stip off the amlogic (SoC) processor instructions, after that there will be a img containing kernel and ramdisk in nirmal gz format.
